Question about Kenmore Washing Machines
Kenmore frontloading washer - loose wire on motor/tach plug
My washer started intermittently not spinning or tumbling. Taking off the bottom front panel, I noticed one of the pins on the motor side of the wire harness to the tach. looked a little loose. Slighting pushing on the wires while the washer is suppose to tumble or spin does indeed get it moving. Also, while spinning, I have been able to press on wires to get the motor to slow down - stop pressing and it speeds up.
I am not 100% convinced it is the tach. pins, perhaps it is another pin or wire that is the problem as it is hard to isolate one wire at a time.
Questions, does the description indicate the problem is likely the tach pins and how does one go about fixing the pins? I am ok with a solder iron, and such, but not sure how to get the pins out of the plug housing, which I prefer over just bypassing the plug altogether or splicing an entire new plug.
Thanks in advance for the advise!
catriver
  • 878 Answers
SOURCE: kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Posted on Sep 24, 2006
SOURCE: Won't spin clothes dry... possibly bad wiring??
Perfect timing for the above problem and solution. My front loading Kenmore model 417.4104200 would, during the final spin time, tumble in one direction a few times then stop and reverse tumble and repeat the cycle until the cycle completed. There would be no abnormal sounds during this time. The drum would not spin at either normal or high speed. The one sentence in the comments from 'catriver' that saved me was, "This model will not go into high spin if the pressure switch detects there is water in the tub." Sure enough there was still very wet towels in the tub. I checked the water pump and found a paper clip which was preventing the pump from pulling the water from the tub. Once the clip was removed, the spin function began performing fine. If I were to do this again, I would try to avoid removing the rubber bellows. It turned out fairly difficult to re-install after I removed and cleaned it. Replacing the clamps without the correct tool was the problem. It looks like the pump can be removed and cleaned out with the bellows still attached.
Posted on Dec 02, 2006
  • 66 Answers
SOURCE: kenmore 80 series washer not spinning
you need the gear box not the timer.
Posted on Dec 21, 2007
  • 184 Answers
SOURCE: Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Posted on Apr 10, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Posted on Jun 20, 2009
Testimonial: "Awesome help and advice -- thank you to everyone!"
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Kenmore He4t front load washer f 06 error code
This answer is actually from Sears Parts Direct: The F06 error code
indicates a drive motor tachometer error. This error is virtually impossible to accurately diagnose. The most suspect components that would cause this failure code are the drive motor, the motor control unit (control board) or the wire harness. In some instances, this could be caused by severely overloading the washer so that it cannot spin properly. Make sure that the washer is not overloaded. Another problem that could cause the error code to be displayed intermittently would be a loose wire harness connection that is affected by vibration when the washer is spinning at high speed. Good lucks, hope it helps
Dec 07, 2014 | Washing Machines
The drum on my kenmore elite 45862 frontloader seems to have seperated from the outside ring. can it be fixed or do i need a new washer
the spider trunnion has broken apart that connects the inner basket to the rear shaft where power connects from the drive motor to turn the drum,most brands you must replace the inner basket and spider trunnion as a unit, as they are not sold separately it will cost you about $350.00 plus oversize shipping
Oct 27, 2012 | Washing Machines
Spin Cycle Kenmore 44052
Possible that the control unit is malfunctioning. You can remove the unit and reset all connections, check for visible track failure or moisture in the unit, if so use a heater to warm off all moisture as it can cause malfunctioning. Finally check the wires to see if there is any that this loose or snapped.
Sep 03, 2012 | Kenmore 98702 Stacked Washer/Dryer
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Kenmore washing machine skips one or both of spin cycles intermittently but timer completes cycle. Lid switch replaced as first try, still have problem. Suggestions?
If I read you correctly the machine finishes the cycle and just doesn't spin? There could be a loose or broken wire in the motor harness. Look in the area where the harness plugs into the motor.
Eric
Oct 12, 2009 | Kenmore 20722
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Repair front load washer
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Kenmore front load tumble action washer
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
