Question about Dell Motherboard Dimension 4100 Intel 815 DP/N: 031REP 31REP 31REP
Computer won't post, and I'm getting no screen
I have a dimension 4100 that will not post. The monitor went blank when I was in the middle of something (just internet browsing), and now the machine will not post and the monitor never receives any input. I thought it might be the video card, but that shouldn't affect whether or not it posts. I've reset the bios, but I still am not getting anything. Is the motherboard totally fried?
  • 3 more comments
  • sj27 May 24, 2009
    I reset the bios by removing the battery overnight as well as clearing the memory via the jumper pins. The monitor always stays black and seems as though it is not receiving any input (it is plugged in and I've tried it on different monitors).
  • sj27 May 24, 2009
    It doesn't post, and nothing shows up on the screen.
  • sj27 Jun 09, 2009
    Thanks for all your help, but this computer is pretty much just shot and I let it go.
    Thanks again!
  • Marcos Anguiano
    Marcos Anguiano May 11, 2010
    so does it post now or still hung?
  • mrninja
    mrninja May 11, 2010
    If you can get to the bios-then the pc already did its Power On Self Test-thats how your able to use the keyboard-so at what point is it hanging?
  • 85 Answers
What i would do is remove all hardware connectors and cards from the motherboard and only leave the power supply and fan connections on. This will most likely allow you to boot the mother board. Remove the RAM as well. I'm aiming at the RAM is bad. But many things can have the same effect on the pc. If you have 2 sticks remove both and boot if you get lots of beeps it usually means it cant find the RAM or Video card. Attach 1 stick in and boot and will make a different beep code error. This prob means you dont have the video card put in the slot. It will not make a beep sound for video if u you onboard video.
Posted on May 24, 2009
I have a Dell Dimension 4100 and when I try to start the screen is black. It says that there is no signal. What do you think the problem is?
there are two cables whith the monitor/lcd one for the power and the others goes to the computer
the message says that the cable is not attached to the computer properly take it out and refix it
Feb 04, 2011 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
EVGA Geforce Nividia 5200 video card. Works with IIYama Vision Maker 450 monitor when using Windows XP. Doesn't work with Ubuntu (Linux). Computer = Dell Dimension 8200. Would like it to work with...
1) Boot your PC
2) when the grub menu appears, use the down arrow to get to the menu option listed as (rescue system)
3) when the text-based menu appears, choose a menu option that gets you to the root shell, then following the instructions mentioned in this link: http://www.cyberciti.biz/tips/black-screen-while-starting-x-window.html. Debian instructions will work for Ubuntu.
Good luck
Jan 18, 2010 | ViewSonic VP230mb 23.1" LCD Monitor With...
Dell 4200 Dimension Desktop, Default Password
Hit Ctrl + Alt + Del twice at the welcome screen, type Administrator for username, and leave the password blank. Works about 80% of the time for me, almost nobody sets the Administrator password.
Feb 08, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
MY MONITOR HAS A GREEN SCREEN
What I get from your post is that you have a green screen covering up your desktop, thus preventing you from doing anything on your PC. If this is what it is Spyware sounds like the issue which you can hold "CTL" and hit "F4" to close it and any other screens and I suggest you run this Free Antispyware: http://www.smcus.net/SUPERAntiSpyware.exe
Click the link or copy and paste it in your browser.
Jul 03, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
