Question about Fuji FinePix S1000FD Digital Camera
No connection from s1000fd Finepix cam to Windows XP.
Recently I have discovered that my camera won't upload pictures to my computer. I plug the USB cord into the computer, into the camera, and turn the camera on. All I get is a blank white screen when I turn it on and the program launcher box is empty. There's no way to choose any program to view or save my pictures with. I've tried a ton of things to get this to work right such as uninstalling my software and checking my hardware but alas, nothing works. Perhaps my cable is no good? Please help me :)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 25, 2012
5 Suggested Answers
SOURCE: Cant upload pix from my fuji s1000fd to pc finepix program.
instead of using the usb plug that the camera has go to best buy, show them your card, and ask for a card reader
what this will do is plug into a usb port, and it will read the data off of the card, completely bypassing the program
Posted on Jan 13, 2009
  • 244 Answers
SOURCE: have a fujifilm finepix s1000fd and when I use
Your cameras focus lens is probably stuck.
It operates via a long metal rod, a pin which follows a track in the side wall of the lens and a tensioned spring. one or more of these has probably jammed causing the focus lens not to move when you zoom.
Unfortunately for this camera, if you cannot free it by switching on/off, tapping the lens etc, you will have to strip the camera down to get at the lens unit. you will have to discharge the flash capacitor before desoldering the control board from the main board before removing to access the lens.
Recommend you find someone who knows about this or send to Fuji.
Posted on Apr 05, 2010
  • 22 Answers
SOURCE: finepix s1000fd
Is it possible you have the self timer ON?
Look for a small clock symbol in the top middle of the view screen or electronic viewfinder. If it is on then hit the down arrow on the 4 direction button until it goes off. There are two self timer settings, 10 seconds and 2 seconds, and off means shoot immediately.
Posted on Apr 10, 2010
  • 11967 Answers
SOURCE: FinePix S1000FD: FOCUS ERROR
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Testimonial: "Hello typrice! I have tryed the following steps: Fix #1: tryed without result by batteries rechargeable NiMH 2600mAh; Fix #2: tryed without result; Fix #3: tryed without result; Fix #4: tryed without result; Fix #5: tryed without result by compressed air; Fix #6: GOAL! I have tapped delicately the bottom and the left/right sides of my Finepix S1000sd on an armrest and in the same moment I have turned on/off more times. Now, my Finepix S1000sd is working! Thanks a lot typrice for your useful help! "
E900 wont upload pictures to my PC
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Aug 28, 2012 | Fuji FinePix E900 Zoom Digital Camera
Need a driver for finepix s7000 for windows 7
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Apr 12, 2012 | Fuji FinePix S7000 Digital Camera
NEED CABLE FOR MY FUJI FINEPIX S1000 TO GO INTO MY COMPUTER,DOWNLOAD THE SOFTWARE, OR MAYBE ACQUIRE THE CD???
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't cost any more than a USB cord.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jan 15, 2011 | Fuji FinePix S1000FD Digital Camera
How do i download pictures fromfinepix a210 to HP COMPUTER W/ WINDOWS ME EDITION
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 29, 2010 | Fuji FinePix S1000FD Digital Camera
FinePix S1000FD Digital Camera: I get a message saying USB Device Not Recognized s...
May 18, 2010 | Fuji FinePix S1000FD Digital Camera
My Fuji 1500s 10 Mp camera will now power on when USB cable is connected. As per the upload instructions on the monitor, I am to plus the USB cable into my computer, then into the camera, then power on the...
You need to turn on the camera while plugged into the USB port. Then pull up the Windows Control Panel. Next go to Scanners and Camera Icon. You should find an icon there with the camera listed. Do a right click and check on Actions. You will then select "run this program on connection" and then select the Finepix Viewer. Turn off the camera and then turn it on and the system will now connect you to Finepix when the camera is connected.
Dec 13, 2009 | Fuji FinePix S1000FD Digital Camera
My photos wont upload
Jul 10, 2009 | Fuji FinePix S1000FD Digital Camera
My computer is not showing when my camera is plugged in
Make sure the camera is turned on, plug the USB cable into your PC first, then into the camera, wait for a beep from your PC to show it has recognized the hookup, then go to "My Computer" and look for the Fuji icon. Don't unplug the camera anytime the lights are flashing on it.
Mar 21, 2009 | Fuji FinePix S1000FD Digital Camera
"Communication Error" when trying to upload photos
Dec 06, 2008 | Fuji FinePix S1000FD Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
