Question about E-Machines (308714) Motherboard
Intall sata drive
I bought an emachines 725 laptop, but the sata driver for xp is not available with installation cd. i want to install xp sp3. original copy is with me. what the solution? pls write
    Sergeant:
    Champion:
  • 212 Answers
Contact your computer manufacturer
Posted on May 23, 2009
Sata drivers for win xp
If you use a XP SP3 install CD it should include the sata driver.
Sep 14, 2012 | Hitachi Travelstar 5K100 HTS541060G9SA00...
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 25, 2012 | Computers & Internet
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
No sound
Click on the link below and choose Laptop, D Series, 725 and download your sound driver:
http://www.emachine.com/support/drivers.html
Good luck to you.
Jan 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
Halt error 4 when installing XP on Vista
XP does not have a SATA driver on the installation CD, you need to either download a SATA driver and when XP ask at the start of the installation you need to provide a SATA driver for the hard disk, press F6, the driver is usually installed from the floppy disk. Alternately if your BIOS will allow you to set up the SATA drive as a ATA drive, do so and after XP is installed then install the SATA driver.
Jun 06, 2009 | Acer TravelMate 5530-5207 Notebook
Vant to install XP on my Acer
you need the sata driver problem is you have to use a floppy disk to put it in... or have it slipstreamed on your cd or get a copy xp with sp3 supports sata installs
Jun 05, 2009 | Acer Computers & Internet
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
I have a hp 6735s with win vista installed in it. i want to use win XP but it wont install in this computer system.what should i do?
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
Solution:
this specific model HP 6735 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
pls dont forget to rate me fixya for this help if u like
pls let me know if i can help u more
Mar 12, 2009 | HP Compaq 6735s Notebook
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
E-Machines (308714) Motherboard Logo
163 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
