Question about Sewing Machines
Elna 7000 computerized sewing machine
Whwn you turn on the machine it goes thru a calibration sequence,the needle works fine,the plate does not work all the time[intermittent].the stepper motors seem fine[lots of torque].it seems to be electronic nor mechanical.   please advise.     thank you
  • trebor12 Oct 21, 2007
    this is not an answer!!!!!!i need a drawing of the machine,as i am an electrical engineer and capable of fixing it ,if only i had a circuit to go by.thanks for nothing!!!!
Just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
Posted on Apr 13, 2009
Elna 7000 will not pick up thread from the bobbin casing. the bobbin casing no longer rotates in circle for sewing to pick up thread. What is the problem?
Posted on Jun 16, 2010
Help!I have ano Elna 72oo.The shaft that holds the needle does not go up and down. The flywheel goes round but nothing happens.
Check to make sure you have not accidentally set the machine to wind a bobbin. That will prevent the needle bar from moving.
Otherwise, it is probably time for service.
Mar 17, 2017 | Elna 7200 Computerized Sewing Machine
My elna 7000 sewing machine speed all of a sudden is very slow, does not work in reverse, or does not want to make any stiches? What can be wrong?
Looks like this is a mechanical machine. If so, bet it needs a good cleaning and oiling. The following may be helpful:
It was working now it seems to be frozen the needle part wont move
Definitely get some good quality sewing machine oil. Sounds like the machine has basically seized, including the stitch selectors.
Apr 26, 2016 | Elna Sewing Machines
When I am monogramming with my Elna 8600, the thread continually breaks, what could be the problem?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Dec 04, 2014 | Elna Xplore 8600 Computerized Sewing...
When this happened to me I was told the thread was old. Sure enough, it was old thread and now that I've replaced that old (20+ year) thread all is fine.
Jun 07, 2013 | Elna 7200 Pro Computerized Sewing Machine
Left needle stitches not being caught by looper
Is the tension on the left needle on its normal setting and is the thread feeding okay to this needle, not caught up somewhere on the aerial or around the cone?
You could try unthreading everything, changing the needles, then rethreading the machine again in the sequence of the threading diagram and test sew.
However, if you have had this machine for a while and are very used to threading it and this seems like a fault to you, then it could be that the looper has been knocked out of timing and it would need a trip to the sewing shop to investigate further.
Apr 08, 2011 | Elna 945 Computerized Sewing Machine
I am looking for an elna 7000 sewing machine workbook, not a manual but the workbook.
you could try Marina's Little SHoppe on Ebay.com, she carries a range of elna service manuals on CD so may have the 7000 too.
Mar 18, 2011 | Elna 7200 Computerized Sewing Machine
My elna 7000, the foot control just quit working in midseam.
What ever you do... don't take it apart and try to fix it yourself. I made a nice little foot warmer out of mine once. :o)
Try ebay or just do a google search for "sewing machine parts"
Feb 06, 2011 | Brother CS-100-T Computerized Sewing...
I have an elna 7000. The rotary hook is not turning and I cannot figure out how to open it up to see if it needs to be cleaned
You may have a broken gear but I do not advise opening any part of a computerized machine, you will need a specialist otherwise you could blow the computer boards with static
Jul 13, 2010 | Elna 7200 Pro Computerized Sewing Machine
Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
Mar 13, 2010 | Sewing Machines
Sewing Machines Logo
1,426 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
