Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
I've noticed that my clothes are coming out as if they have never been washed. I watched the last wash cycle and noticed that during the wash cycle it does not look like any soap is draining down. There are no suds and clothes are coming out dirty. I looked in the the soap dispenser and all the soap is gone.
I have a whirpool duet, front loader. Model number GHW9100LW2. It is about 5 years old. I am using HE liquid Tide as I always have and am not overloading the cycle. Any help solving his issue would be appreciated
  • 1 more comment
  • jeanagreene May 23, 2009
    I checked and the water is getting to the soap try as it should. Any other suggestions or areas I should look at?
  • jeanagreene May 24, 2009
    There is no standing water when the cycle finishes. Does that mean it drains out properly?
  • Paul Hutchinson May 11, 2010
    Have you checked the water is getting in via the correct part of the tray? If it's not may indicate a faulty inlet valve or blocked pipe/tap filter.
  • 909 Answers
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
Posted on May 24, 2009
  • Paul Hutchinson May 24, 2009
    Yes, it looks like it's draining. But check the filter any way as you never know. If that won't cure it then I'm unsure what to suggest.
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Whirpool Duet Washer leaks from the door
Make sure the transit brackets and screws have been removed.
Other than that,I would say it needs a new door, as it is possibly twisted, and not closing tightly enough against the door seal.
Plz rate my suggestions.
Thanks.
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water in the baskedt
yes it is the problem replace the water inlet valve
this is done by removing the top you will see the valve that the fill hoses connect to
make a diagram of the connections so that you get it right when you reassemble the unit
May 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Long wash cycles
WHEN YOU WASH IS THE WATER HOT ENOUGH IN A REASONABLE TIME? ALSO DOES THE WASHER SENCE THE AMOUNT OF SOAP THATS IN THE TUB. IT COULD BE GIVING ADDITIONAL RINCES TO REDUCE THE SOAP CONTENT.(TRY WITH NO SOAP IN SYSTEM AND SEE IF TIME IS SHORTER)
Sep 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
450 people viewed this question
Dan Webster
Dan Webster
Sal De
