Question about Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P...
Ice maker stopped
Whirpool refrigerator gold series. stopped making ice, arm is down
    Brigadier General:
  • 8,619 Answers
Hi!
Please check these:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
It quit making ice - water comes out the water side--the dispenser works until bin is empty
some ice makers have an arm on them that stops producing when the box is full and sometimes it sticks in the ff postion
Mar 10, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Oct 30, 2012 | U-Line Uline Origins Series...
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our ice maker is not making ice. It's turned on but no ice is being made.
Check to see that the stop bar is down and that water is in the tray.
No water is often a bad inlet solenoid or water to fridge not on.
Sep 14, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Open Questions:
See all Whirlpool Gold Series GI15NDXT 15" Automatic Ice Questions
Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P... Logo
592 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
