Fault code _h20 fault code indeset we 16 washing machine
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
T indeset washing machine showing f11 fault
Contact costomer care font don't do anything. Otherwise machine will be damaged
Nov 05, 2016 | Washing Machines
Error code h20
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
H20 fault code splendide washer
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Nov 19, 2013 | Splendide ARWXF129W - Washer 24" Whit...
Fault code h20 flashing on indisit wie127 washing machine
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Jan 21, 2010 | Indesit W 123 Front Load Washer
Indeset w101 washing machine programer, we set the
Depending on the model you may have a reset point on the selector switch dial.
This is usually indicated by 2 or 3 black dots on the dial.
If it has , then switch the m/c off, set the dial to one of these points, switch on and wait until light fashes, switch off, and reselect your programme.
It should now work normally.
If it does not, then there is probably a control board fault.
If there is no reset point, then again it is likely to be a control board fault.
Thankyou.
Jan 15, 2010 | Washing Machines
Does not complete cycle comes up with -H20 on screen
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Thanks.
Nov 07, 2009 | Indesit Washing Machines
My hotpoint washing machine will not wash and is flashing h20?
H20 is a fill fault. check water taps are turned on, inlet hoses are not kinked. if ok then a possible fault with the inlet valve(s).
Oct 30, 2009 | Electrolux Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Got a fault code f11 on indiset washing machine
I HAVE GOT FAULT CODE H20 ON MY HOTPIONT
Apr 19, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
