Question about Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards
1992 150hp merc black max and hydraulics won't work, sounds like a sick animal.
I have a 1992 150 hp merc black max and the power trim and tilt sounds like a sick animal and won't go up or down. I have it to low to take for a look at, any advice?
  • 86 Answers
On the bottom of the trim/tilt cylinder there is a big white slotted head screw usually located on the right side. Turn that out about 3 turns. Have someone help you manually lift the engine and while it is up tighten that screw back up and it should stay. From there you can check your trim lines and check the Cylinder for leaks. Also check to make sure that there is no water in the system. Once the engine is all the way up just engage the tilt lock and you will be able to do anything that you need to without fear of the engine bleeding back down.
Posted on Aug 03, 2009
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 | HP Boating
The tilt trim motor will not raise or lower the outboard motor.
Use a multimeter to check that power is actually getting to the motor when you operate it. As you have suggested, the relays may be the problem, as they have bad contacts so no power is getting to the motor, in which case you need to replace the relays.
Jun 16, 2016 | Boating
What could be my problem with two items one is my motor cannot get on plane and two my power tilt makes a racheting sound.
the first item is there is insufficient fuel supply for full power
if a carby machine then have the carby fully overhauled by an accredited shop, replace all rubber fuel lines, filters and recondition the fuel pump
if efi then check pump pressure , replace all rubber fuel lines
noisy tilt rams may be low oil in the hydraulics, water in the hydraulics or sucking air in the pump or jamming /rusted rams or rusted pivot bushes for the motor mounts lack of use will contribute to most problems as things corrode and rot
May 20, 2015 | Boating
Suzuki4stroke 150 hp will not start, new battery gets juice just clicks
starter solinoide sounds like it failed if its clicking ! remove engine cover and as a friend cranks the key listen where the click is and it will have the +wire from battery and then a wire to starter , check connections are tight and if all ok then replace solinoide !
Sep 07, 2014 | Suzuki Tilt Trim Motor, DT 150-200...
Evinrude 50 HP outboard tilt and trim
sounds like the motor has give out . the clicking is probably the relays
Jun 14, 2013 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
My tilt on a yamaha ox66 200 motor quit working,what should I try first?
Step 1:
Operate Trim Switch Do You Hear Clicking Sound In Engine
Yes ,No
Step 2:
If Yes Check Wiring To Power Trim Motor are All Cables Tight
If No Then The Trim Relay And Or Trim Switch Is Probably At Fault
Step 3:
,Remove Three Large Color Wires Going To Power Trim Motor Black, Blue And GreenConnect Black Direct To Negative Battery And Blue To Positive Battery Motor Should Trim Up ,Remove Blue Then Try Green To Positive Battery, Motor Should Trim Down ,If Nothing Then Trim Motor Is At Fault If Works Then Trim Relay/s Are At Fault
Jul 03, 2010 | Boating
My 1978 140 evinrude electric trim tilt motor working but wont lift or lower happend suddenly after it lifted.maybe the pump?
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
Jun 06, 2009 | Boating
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Logo
904 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
