Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Water is running out the gas pool heater
When we opened the pool and turned on the filter water started sprouting out of the heater? What is broken?
  • 2,463 Answers
Hi could be a spilt heat exchanger did you drain all the water out of it
Posted on Feb 17, 2010
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
HL1 error water not heating
check gas pressure if ok check manual bypass see if spring is ok if broken or stuck closed that if ok see if unit is turning off check gas pressure to see if running out of gas and turning off then gas line filling up and turning on again
May 21, 2012 | Raypak 266A Digital ASME Natural Gas IID...
Hi. I just bought a house with a pool and Raypak RP2100 heater. The pool company came out and opened the pool and started the heater. It ran for a few days and has quit running completely. the pilot light...
Thank you for posting your question here on Fixya.com.
What type of filter do you have: Sand, Earth (DE) or a cartridge? The most likely reason it worked and has since quit is your filter has become dirty enough inside that the flow thru the pump and heater are reduced too low...there is a switch in the heater that senses this and turns the heater off to avoid boiling the water. Cleaning or backwashing the filter should fix the problem. If you have a sand filter or a cartridge filter look at the valve and see if there is a recirculate setting. If so, turn off the pump and change the valve to this setting. Turn everything back on...the heater should start to work. This would verify the filter just needs to be cleaned.
If you need help with the filter please add a comment with the filter details.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 19, 2011 | Raypak 130,000 BTU Natural Gas Pool...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
Aug 17, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool heater will not stay lit
check your ignition status. if you have a pilot ,make sure its lit. if you have a glo ignitor, make sure its glowing when you turn on the heater. sometimes it will glow but it might be hot enough to open the gas valve. also be sure to check your gas supply and make sure you are getting fuel to the unit.your heater will not turn on if your pool filter mode is enabled.
Jul 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
156 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
