Sigh... first world problems.
would you like someone to pop round with some fresh batteries and install them for you?
have you even tried a wall wart or power supply?
Look on Power Supply board for Bad Capacitors they will be vented or puffed up on Top , 1000uf 16v 2200uf 10v 330uf 10v or replace the power supply board Encompass Parts Distribution 1-800-638-3328. Look on website at Shopjimmy.com
Hi A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage. Hope this will help in solving....
Sorry it took so long to give you a reply to your question. The problem you are having the resetting the Clock's function is covered in the owners manual of the product. I am giving you a web link page, that will take you to the Emerson Customer Support main index page for owners manuals. Here you will be able to find your make and model of Clock/Radio. Just open the page and you will be able to make the adjustments by reading the instructions from the owner's manual.[http://www.emersonradio.com/owners] Copy this link and paste it into the address bar of your web browser. You will need a pdf reader and writer to read the manual and make a copy for your use. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
