I/O Device Error, won't read disc or anything Light stays on
My light on my DVD stays on and when I go to the drive it says.. Is not accessible The request could not be performed because of an I/O Device Error. I tried installing the firmware for this product , the DVD flashed while installing that.. and also the online where you got to manage the computer and change some setting and still nothing.. I hope this means it's dead
    Sergeant:
    Champion:
  • 212 Answers
Your player is not recognizing the disc.
Posted on May 23, 2009
Blue disk light on until console unplugged now games won't work
One has nothing to do with the other. It's a coincidence.
The blue light means that there is an update available from Nintendo to be installed. It could also mean that you received a message or news from Nintendo. If you don't like the blue light, you can change it in the wiiconnect24 settings.
If your Wii isn't reading games, the first thing to do is to check the disc. If it is not scratched or no discs at all are working, your drive needs to be replaced. You can find a new Wii DVD drive replacement at the following page:
Wii Replacement DVD Drive Repair Part
Jun 22, 2013 | Nintendo Wii Console
It won't play a dvd! and when it does it just sits like it is stopped!!
Hello
Eject the DVD from the Cyberhome DVD player. Look over the bottom of the disc. If any dirt and fingerprints are present, remove them with a damp cloth, moving from the inner circle of the DVD to the outside.
Insert the DVD into a scratch repair device, if the DVD has any light scratches (deep scratches are not reparable). Turn on the DVD repair kit and the device literally sands down the scratch. When this is finished, the DVD should work correctly with the Cyberhome DVD player.
Avoid inserting homemade DVDs into the disc drive. The Cyberhome is not compatible with many self-created DVDs, causing a "Disc Read Error" message to appear on the screen.
Spray compressed air into the disc drive of the DVD player. The compressed air removes dust and other debris from the laser and reading lens in the player.
Apr 25, 2011 | Cyberhome CH-DVD 300 DVD Player
MY CONSOLE KEEPS SAYING CAN'T READ DISC
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Nintendo Wii Console
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Cd rom dose not read disc & will not update
you want to buy new cd drive from workshop if the problem stay then go to workshop and get checked the motherboard it may possible the error of the motherboard chipset
Jun 06, 2009 | Gateway Computers & Internet
My DVD Ram drive is not reading any CD/DVD
The most common reasons for a power calibration error is a dirty lens or bad media. Clean the lens with a short burst of cabbed air or carefully wipe it with a cotton swab.
Good luck.
Mar 17, 2009 | Microsoft Windows Vista Business DVD...
Device stopped to read any disc
for EnzoMolinari
u r drive is having an hardware problem just contact nearby service center
Apr 27, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Dvd combo not reading/writing any CD
since the device can't identify a disc anymore it is adviseable to get another.
Uzowuanya
e-mail: uzowuanya@yahoo.ca
Feb 13, 2008 | Computers & Internet
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
