Question about Acer Aspire 7720-6155 Notebook PC
I formated completelly hdd (acer 7720g) i want to to recreate pqservise in order to have d2d recovery(recovery management).i have the dvd recovery of factory settings but the dvds didnt manage to create the hidden partition and the d partition .there is only 1 partition (c) how can i acceess the original factory settings on my hdd. i need the recovery management.. thank you!
  • 21 Answers
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
Posted on May 24, 2009
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer 7720g f11 does not working in order repair my pc to factory image...i have the dvd recovery and i have testing a couple of times the settings of hdd ( os or fat 32 with partedit32).Also when i use the...
Hi there.
If F11 is not workings as it sometimes does, then pop the recovery DVD in the drive and try hitting F12 as the computer starts up so you can change the boot order without going into the bios.
If you do not have this option the enter the bios by hitting F2 as it starts up, once in the bios look for the boot order and change it to CD/DVD as the first boot device, hit F10 to save the changes and exit the bios, the computer will restart and you should be able to boot from the recovery disk and restore the PC to factory condition.
Please post back if you need anymore assistance.
Good luck and thanks for using FixYa!!
May 25, 2009 | Acer Aspire 7720 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Acer Aspire 3053WXCi D2D Recovery
Then You Apparently Formatted Over Your D2D Partition...
Jan 07, 2009 | Acer Aspire 3050-1733 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Cheers
Jun 17, 2008 | Computers & Internet
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Apr 08, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
D2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Oct 16, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 7720-6155 Notebook PC Logo
506 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
