Question about Karcher 2500 PSI Pressure Washer
Karcher 2600 (Honda engine) has lost pressure.
For two years this was the perfect machine. Then, poof, the pressure seems to be at about half or less of what it was. I've tried different nozzles, etc.
I'm not sure if this could possibly be related, but the Honda engine only runs smoothly when it is at half-choke. If I push all the way to "run", even after being warmed up, in chugs and dies.
  • 92 Answers
Dear Modad,
First one must see if the problem is in the Honda engine or in the pump. So you must try the Honda with no load. You can remove the gun from the pump, but leave the water supply going into the pump. In this way you still have some cooling effect from the water. Now with no load you try the Honda engine. If it is possible tune and set the Honda engine to work correctly. Now if the Honda runs smoothly,...then the problem is in the pump. Regarding the pump try the system by attaching the gun with no NOZZLE/ or LANCE. Open and close the gun to see reaction of Honda Engine. If in this case the Honda runs OK....then attach a NOZZLE so that you have pressure and load. If the Honda starts to die down, this could be that the Honda needs servicing. This like having a car and uphill it will stall and dies down. Here the engine needs servicing. One small thing to look for. I came across Honda driven pumps which have a cable coming from the Honda's carbureter to the head of the pump. When the gun is released the cable is pulled from the head of the pump by means of a piston type valve and this in turn will reduce the speed of the Honda. As you see it is difficult for me to pinpoint the real cause when I do not know the model number and type of pump you have. But if you go by these guide lines you shuld find the fault. Remember...ALWAYS try HONDA ENGINE without load first. I also wish to add that the Honda could be working OK...but then the pump has some problem that it is stopping the Honda. So the pump could also for some reason be jammed and this needs the pump to be serviced. Another hint is very simple. If the Honda is not getting to its maximum power and revs...then the pump will drop pressure.
I gave you various hints to tackle the problem by simple elimination. But you must be able to know how to service the Honda or Pump yourself. To repeat and remind you...check the honda and service the Honda with NO LOAD!! Thyen tackle the PUMP.
Regards,
Fulltech.
Posted on May 24, 2009
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
I have a excel 2600 psi and there is no spark, the engine is a Honda
could be many things...get a new spark plug...check plug lead not rubbed and shorting out on body...take flywheel off and check/replace cdi...or points if it has them.
Jul 24, 2010 | Karcher 2500 PSI Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
I have a Honda 2000 pwr. No pressure
check the o-ring in the pressure relief valve.
Sep 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
494 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
