Question about Microtech JTX V5 15" Flat Panel LCD Monitor
Power the monitor and blank in fewsecnd
When the power on the monitor and blank the few scend
    Sergeant:
    Champion:
  • 212 Answers
Is it a new monitor? Actually sounds like a hard drive issue.
Posted on May 23, 2009
    Problem Solver:
  • 11 Answers
This could indicate your video card has gone bad.
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Picture ok for a few minutes then go blank
It's not the monitor it's your video card replace it
May 20, 2009 | Dell E176FP 17" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Whilst using my computer the monitor went blank. I turned the monitor off and back on. It stayed on for less than a second before going blank again. There was power to the monitor. I left it for a few...
can u boot into the safe mode and see if the monitor will work cause it sounds like to me that you either have a driver that is failing or the monitor is failing
Aug 18, 2008 | HP Computers & Internet
Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Aug 17, 2008 | HP L1706 17" LCD Monitor
Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
Oct 19, 2007 | HP Pavilion F1703 17" LCD Monitor
Microtech JTX V5 15" Flat Panel LCD Monitor Logo
77 people viewed this question
Top Microtech Computers & Internet Experts
William Miller
William Miller
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Microtech Computer and Internet Expert? Answer questions, earn points and help others
