Question about Maytag 24 in. MDBH950AW Built-in Dishwasher
Grit in dishwasher
We have had a problem with grit getting all over the dishes. At one point we had found some information about blowing out the rinse arm. It seemed to help temporarily but now.... It's like someone has thrown a cup of sand in there and it's blowing all over the dishes in the top rack.
  • 3 more comments
  • Weedysue Oct 20, 2007
    Well we have checked the temperature and it's 126 right now. However, in the process of checking the temperature I noticed that the wash arms had not moved in the 5 minutes since I check the last time. There is water coming from them but they just aren't spinning. What might we look at next? Any idea?
    BTW I am running the dishwasher empty. So I know that nothing is blocking the arms from moving.
    Yes it's covered
  • Anonymous Jan 31, 2008
    I have the same problem! The dishes seem to be getting clean but a sandy grit is on them when the cycle is complete. It is not a white substance that might be from the detergent--this is brown like. So what can I do? I have to rerinse all my dishes! It is driving me nuts.
  • Anonymous Feb 20, 2009
    Exactly same problem. Only got dishwasher a month ago & it cost over £400! Shocking. Tried all programmes & added rinse aid even though we live in a very soft water area.
  • 4,889 Answers
Sounds like you have a low water fill problem or maybe a water temperature problem. The water should be at least 120 to 130 degrees Fahrenheit to start with. Gel soaps can cause a lot of problems with scum and leaving a white residue, mostly when there is not enough water in the dishwasher. After it fills there should be water almost up to the heating element. Also look for the water draining by itself.
Posted on Oct 20, 2007
  • eagle338
    eagle338 Oct 20, 2007
    Check to see if Normal water fill covers the filter area..IF not this is one of the reasons for the spray arms not rotating..
Dishwasher leaves cloudy grit on everything
Is your state one the banned phosphates? If so, try adding a tablespoon of TSP to the detergent. If not, is there galvanized steel in your water supply? The grit in most washing aids removal of food on the dishes but is supposed to be gone by the rinse.
Nov 30, 2013 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Gritty Dishes
The only thing that can cause grit in the dishwasher is something you put in it or it's not rinsing as it should. As you use tablets we can probably rule that out. If you don't have hard water we can rule that out too.. So next up is not rinsing properly. The spray arm in the bottom of the unit has little holes in it. Many times junk that gets by the filter end up in these holes. When that happens the water will not spray out correctly, your dishes don't get properly cleaned and rinsed. Pull out the bottom rack, you might need a flashlight but you need to look at each hole in each arm and see if they are clogged. Even if you don't physically see anything remove the spray arm and clean it, sometimes stuff will fall back into the arm when there is no more water trying to flow. It is very easy to remove. Anyway, remove the spray arm, pick out anything you see stuck in the holes, run water back thru the holes in your sink and re-install the spray arm.. Hopefully this is your problem. Here is a video (it's not mine) which shows how to remove the spray arm.. good luck !
Jan 23, 2018 | KitchenAid 24 in. KUDS25SH Built-in...
After cycle, there is grit on my dishes
sometimes I have found if the arms are not freely going around then this can leave grit or if you have run out of rinse aide..the filters are usually in the bottom of the machine..hope this helps
Apr 16, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishwasher repair - Bosch
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
Jan 25, 2009 | Dishwashers
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Jan 19, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag 24 in. MDBH950AW Built-in Dishwasher Logo
759 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
