Question about Kenmore Dryers
Dryer takes long time to dry clothes
My gas dryer takes forver to dry even though i can feel adequate heat
  • Kenmore Master
  • 3,361 Answers
Remove the rear connecting vent and try a load at 45 minutes time dry. If it dries correct the vent blockage problem.
If not, let me know for step 2.
Posted on May 23, 2009
Does not get hot enough
Some dryers take fifty forvers to dry clothes if the blower wheel is loose. Usually hear a rattle nd the filter will be warped from the over heating. Once she overheats from improper airflow she shuts down the heat. Takes a long time to dry but it eventually does do it. Replace blower wheel this is on norge style dryers with filter inside door. On other models what Floyd said in his links..
Dec 29, 2015 | Dryers
My Whirlpool dryer tumbles but no heat. The clothes dry after along period of time and that is when i finally feel some heat.
Probably needs a good cleaning. If it was me I would remove the filter housing and do a through cleanup. make sure the vent going outside is not blocked. The dryer must have adequate airflow to work well.
BEFORE AND AFTER
Oct 03, 2012 | Whirlpool Dryers
It takes 3 hours to dry a load of clothes. it takes a long time for the dryer to heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Kenmore Dryers
My gas dryer does not ignite all the time, so my clothes are taking a long time to dry.
heatman101;';
Jul 30, 2011 | KitchenAid KGYS750LQ Gas Dryer
Clothes not dry. Take about 3 hours to dry the medium load of regular clothes.
heatman101'
Jul 18, 2011 | LG Dryers
No or poor heat from dryer what do i check first i cleaned all dryer vents sensor dry reads double than normal too start ,clothes take 2 or 3 times to dry
heatman101,,./'
Apr 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
The dryer doesn't heat up and dry the clothes. I checked the troubleshooting section and then cleaned the lint filter, which we do after every time we take dry clothes out, and then I made sure the exhaust...
heatman101
Sep 28, 2010 | Bosch Nexxt 500 Dryer
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
It ignites but does not heat hot enough to adequately dry clothes even though the gas is ignited. Doesn't appear to be hot enough. Amana ALG643RBW.
take the exsaust off the back of the dryer and run a load with it dettached and see if this makes a difference and let me know
Jun 21, 2009 | Amana ALG643RB Gas Dryer
Dryers Logo
126 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
