Question about Whirlpool AWM8163 Front Load Washer
Washing machines door open light is on, but door is shut
My washing machine is Whirlpool awm8163. The door open light is on, even though the door is closed. When I started the cycle it started to let the water in for a few seconds, then it stopped and started making a beeping noise and flashing the letter F and number 7. Can anyone help please.
  • 73 Answers
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
Awo 9763
Hi Lisa. I'm not familiar with the particular machine but I suspect that if you look just inside the machine near the door catch you will see a small button/lever that operates a switch. (look up microswitches on net). Switch either needs adjusting or replacing. You could try holding the switch closed with your finger or something to see if the machine is going to work - if it does look like working (filling?) the switch just needs adjustment.
Apr 10, 2014 | Whirlpool Washing Machines
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
Jan 23, 2010 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM 8123/S washing machine has died.
It turned out to be nothing more than one of the spade connectors shaken loose. Even I could handle that!
Cheers anyway,
Mxxx
Aug 27, 2009 | Whirlpool AWM8163 Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
Mar 30, 2009 | Whirlpool AWM8163 Front Load Washer
What does fault F6 mean in Whirlpool washing machine AWM8163/3?
Hi there. This code F6 means that you are experiencing Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Please rate and god bless..
Mar 19, 2009 | Whirlpool Washing Machines
Whirlpool AWM8163 Front Load Washer Logo
499 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
