Question about Bernina Virtuosa 160
Machine is not sewing properly
I was sewing through sticky back velcro and my thread kept breaking off. Now it is not sewing correctly. Seems my bottom thread is not catching with the upper thread. The upper thread get all jumbled up. Please help. Sue :(
  • 22 Answers
Hello Sue
It sounds to me as if you have knocked the timing out on the machine , you will need to have your hook timing adjusted. Also check the height of your feed dogs (at the highest point the feed dogs should be 1.1mm above the plate), If the feed dogs were too low when you started out with your project it would of caused you material not too feed and binds up the machine and knock the timing out
Posted on May 03, 2010
    Problem Solver:
  • 33 Answers
Use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
Posted on Sep 28, 2009
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
My thread cutter cuts the top thread with every stitch
that is a possibility and is a reason that I don't use self adhesive velcro any more
I just put in a new needle and that fixed the problem
if it started with the velcro then that should fix it
Jun 19, 2015 | Great Plains Ind. Juki TL-2010Q 1-Needle,...
Brotherps31 instruction manual
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
to find a manual, we have to know the model number of the machine
to to
Jul 14, 2014 | Brother LS-2125 Mechanical Sewing Machine
Thread breaks when trying to sew velcro (with sticky back substance) on rayon material. e
Use a larger diameter needle and sew at half the speed also, find Velcro without the sticky backing. that will ruin your machines lower thread paths (Bobbin case and hook areas) and cause more issues when you are done with the Velcro sewing.
Jan 31, 2014 | Singer Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
Top thread keeps breaking, I've re-threaded to make sure it's right, wound and re-inserted a new bobbin, checked the needle to make sure it's not bent (as described in the manual) and put it back with flat...
Not sure if you noticed but if you thread a machine with the pressure foot down it will not thread correctly. There are two little things that sorta looks like symbols for the tension on most machines. (learned this when my viking 600e kept breaking thread and I put it in shop) If you thread the machine with the pressure foot down it closes the symbol things and the thread will break as you described. If you have completed that correctly check the spool of thread. You may have a burr on the thread spool that is catching the thread that too has happened to me.
Mar 30, 2017 | Brother LS2125i Sewing Machine
Newly bought Magnolia 7330 and the needle thread keeps breaking. I took it back to the place of purchase and they said it is working fine...watched me thread correctly. I've changed thread, needles and...
This sounds silly, but I have the same machine and it kept happening to me too. Here's what I was doing wrong: When I thread it between 6 (thread take-up lever) and 7 (lower thread guide), the thread was being left exposed on the face of the machine instead of falling into that little **** of a crevice. One I figured out to stick it in the **** of the crevice, all was well. Try that -- and good luck!
Jul 07, 2010 | Janome Magnolia 7330 Sewing Machine
Top thread on machine keeps breaking , sews for a while, jumps a few stitches then breaks. Seems to make one long stitch every so often.Thanks
Refer to the manual for threading and thread the machine with the presser foot up.
Make sure the bobbin is inserted so the bobbin thread is feeding in the correct direction from the bobbin spool and through the proper guides.
Mar 08, 2010 | Singer 3116 Simple
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Aug 03, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
267 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
