Question about Philips Televison & Video
Bad stk? my 51'' magnavox uses stk392-120 i have replaced them and now it only chirps . is there a a more durable upgrade ic?
  • phillipbalaz May 24, 2009
    i replaced all the 6.8 metal film resistors then all the 100 ohm resistiors . the pisture was askew on left side and could not adjust convergence left to right but could up and down . put new stk's and 6.8's in system booted up and picture was funny looking then it acted like it was adjusting then picture stopped and it started chirping then i pulled all the resistors and checked them 100 was about 5 ohms off . same with 6.8's any where frome 3 to 10 ohms so i put them all back in then put 1 of the original stk's back in n have picture but the same as it was in the begining
    President:
  • Philips Master
  • 1,779 Answers
Sure, Stk392-180, I use them all the time instead of the 110 and 120. Was your convergence out and that prompted you to replace the Stk's? If you had a picture before ( but bad ) I would check for the 6.8ohm bias resistors. They must be on the money, if not, they will destroy your Stk's in a heart beat. They are all located right buy the Ic's all in a row. Don't forget to clean the heat sinks off then apply a bead of Heat Sink Compound across the middle of the Ic's before installing them. the resistors may not be the value I stated, so measure a few, that will tell you,
Posted on May 23, 2009
  • Jim Krause May 24, 2009
    The resistors MUST BE 6.8 ohm ,,,not 3 not 10 but 6.8, I do them all day long. The IC's will stand for nothing in-between without going up. some are in parallel which they will measure 3.4 in the circuit as you know. It's best to remove 1 leg then check them.
    Your going to have to replace the STK's again because they went up and that's what took out the resistors. When your converging the sides, don't try to bring each on target the first time. Bring it in or out 1/2 the distance then go to the next one all the way around and repeat the process over again. If you want, give me your e-mail address and we can go from there.
I have a very similar problem.on a Hitachi 50UX52B. I just pull the chassis to replace both Convergence Amps (STK 392-110) But am now on hold after reading your solutions.
I discussed this on Riddledtv.com under http://www.riddledtv.com/forums/red-convergence-hitachi-50ux52b-soldering-heat-sink-t1384,highlight,hitachi.html
and included a picture of the problem. I also have the service manual that I will be happy to share. I would really appreciate your input and comments.
Posted on May 25, 2009
Poor convergence on my 60"
It is very possible that the IC's were not installed correctly. Check and make sure you do not have any solder bridges on your pins, or that the solder pads did not pull up from the board. If all that looks good, check your resisters that are in circuit. It is possible that 1 or more was already week and popped when the new STK's were installed. Also as far fetched as it could be, you might have gotten defective parts though not likely. I hope this helped and good luck to you.
Aug 10, 2011 | Philips Magnavox 51MP392H Rear Projection...
I WAS TOLD I NEED A NEW BULB....IT WAS WORKING FINE AND THEN NOTHING...MAKING A SMALL CHIRPING REPETITIVE SOUND...YOUR THOUGHTS, THANKS
This problems,it is also the causes by the tv convergence board,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved this chirping problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have red convergance problem.. This is the second time I have replaced all diodes and the stk chips. they dont have any 110 stk chips so i am using 150 stk chips. I replaced all diods and now RK 62...
Alot of techs recommend using the higher wattage ICs to replace the stock ones, which is never a good idea since the resistors get stressed. Upgrading to the STK394-160 IC is the only upgrade Hitachi recommends but then the values of the resistors need to be changed since the stock resistors will not work with the upgraded ICs
Oct 09, 2010 | Hitachi 61HDX98B 61" Rear Projection...
Hi Ladywin, I have question regarding your fix on convergence problem pasted below: Is the reason to replace STK***-110 to STK***-120 or 150s, is because theyare more durable? "Start out with...
She does not appear to be here but I can assist you.
You have convergence problem? Give me brand and model and I will tell you what is needed.
SD TECH
Sep 01, 2010 | Televison & Video
Chirping tv turns on-off every 2-3 seconds until unpluged
I hope you replaced the bias resistors at the same time. If not, then the ic's have gone out again. Double check your soldering that no pins are bridged.
Mar 04, 2010 | Philips Magnavox 51MP392H Rear Projection...
Double vision
Hello:
You need to have the convergence IC's replaced, the part # is STK-392-110 replace them both as if one is bad the other is soon to follow. Replace them with STK-392-120 for longer life. They are large black IC's mounted on a metal heatsink.
Dec 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
I am seeing double on my tv how can i fix this problem.thanks
Replace Both of your STK ICs and 5 or 7 low ohm resistors if your stks are 110s , 150s, upgrade to 180s.STKs are your convergence ics they are the big black ics will have part number on them STK392-110 etc...
May 20, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
