Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
How do I access the thermocouple on my Laars Lite, LLD-400N
My pool heater lights then shuts off a few seconds. That could mean my thermocouple is defective or dirty. Cleaning it w/ steel wool sometime does the trick. I just can't figure out how to get to it.
    President:
  • 3,433 Answers
Whoo told you it does the trick?The only trick I know that works on a thermocoupler is replacing it with a good one. It is the probe that sits in the pilot flame. If you take it out to scrub it, you may as well put a new one in its place . They are relatively inexpensive.
Posted on Jun 01, 2009
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a larrs lite lld 400 n it heats up but it doesnt get hot enough
if you have a bypass made of plumbing only open 1/2 way if you don't have one put one in if you slow the water down it will heat more per pass
Sep 18, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light won't ignite.
One possible reason could be a bad thermocouple. This is a rod shaped device that is close to the flame. It's function is to turn off the gas if the pilot light goes out. Heat from the flame operates the thermocouple. When the flame goes out the thermocouple cools off and shuts off the gas. When one goes bad it will not let you light the pilot. Here's a picture of what one looks like. There's a bracket that holds it in place.f023fa6.jpg
May 02, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Lars Lite 2 pool heater will not ignite
The easiest way to troubleshoot any heater, is to call the manufacturer. Their techs will walk you through each possible problem and solution until you find the answer.
Sep 11, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
759 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
