Question about Dell E173FP 17" LCD Monitor
Power ok no display - Dell E173FP 17" LCD Monitor
    President:
  • 1,185 Answers
Tilt the screen so that light strikes it at an angle
If you look carefully at the screen can you see an image in the background.
If you can then the inverter for the backlight or the backlight itself has failed
No image is the LCD
Cheaper to buy another monitor !!!
Posted on May 23, 2009
  • Dell Master
  • 1,684 Answers
It sounds like you have a bad LCD inverter in the unit. Many of these can be repaired. We have a repair service for LCD monitors if you are interested. Our repair service runs $35 including return ground shipping. You can contact me at buddy@ccl-la.com
Posted on Jun 17, 2009
Tip
How to reset an HP printer waste ink tank aborber (only work on certain models)...
Press and hold the “left arrow” key.
Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release the “OK” button.
The Display should say “Support” and display the FW rev (something like R0616R)
Press and release the right arrow button until the display says “System Configuration Menu”.
The display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
The display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display the message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”.
Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
on Jan 02, 2010 | Office Equipment & Supplies
0xc19a0002
Switch on your printer.
Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special Key Combo
Press and releasethe key in sequence 1, 2 and 3 buttons.
display says "support" R0631M
Press and release the right arrow button until the display says " System Configuration Menu".
OK button.
Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status
Press and release the OK button.
Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page..
Oct 10, 2013 | HP Photosmart C6280 Printer
No display
If power problem then check you power connector. If power ok or display problem then you follow instruction:-
> Check CPU power, proper coming or not.
> HDD on or running ok conduction, if HDD not detect proper then not display.
> Check RAM slot or RAM ok conduction.
> Disconnect all power supply and some movement wait then reconnect all section and power on.
I hope display coming.
Thanks
Sep 09, 2013 | ViewSonic Computers & Internet
0xc18a0001 Error. I've tried several recommended procedures from your site....no luck. Any help would be appreciated
Solution 1
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Solution 3 (Conversation with a HP TECH)
Earnest: May I have the model number of All-In-One you are using?
james cowan: c6250
Earnest: Thank you for information.
Earnest: James, please let me know the room temperature in which printer is replaced
james cowan: 67 degrees f
Earnest: Okay
Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
james cowan: ok
Earnest: Press and hold the "left arrow" key.
Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
Earnest: Please ignore the above steps, James
james cowan: ok yes nothing seemed to do anything
Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
james cowan: COxxFN0723BR
Earnest: Okay
Earnest: 2. Press and release the right arrow button until the display says "System Configuration Menu
james cowan: ok
Earnest: 3. Press and release the "OK" button.
james cowan: ok and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
james cowan: ok
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Earnest: Let me know once you are done with the above steps
james cowan: ok its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
james cowan: ok
Earnest: Let me know the message displaying on the front panel of the printer
james cowan: printer preparation occuring - do not interrupt
Earnest: Okay
james cowan: ok its done
Earnest: Let us print a self test page from the printer now
james cowan: ok deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
james cowan: ok printing
Earnest: Okay, please check whether all the colors pritned perfectly on the test page
james cowan: perfect
Earnest: Great..Cheers!!!
james cowan: thank you very much
Earnest: James, now you can continue using the printer
Earnest: I appreciate your efforts and patience in trying to resolve the issue.
Solution 4
  • Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
  • Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal". Display should say "Support" and display the FW rev: COxxFN0723BR (or something like that)
  • Press and release the right arrow button until the display says "System Configuration Menu"
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "CANCEL"(Annuler) button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 60 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
  • print a test page:
Courtesy of LEH.
Jul 02, 2011 | Computers & Internet
0XC18A0101
A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
May 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Failure to print
Please follow the below steps.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Arter all these steps, if the issue still persists, please follow the below steps.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
Apr 18, 2010 | HP Photosmart C6100 All-In-One Printer
Blank display no functions power ok
Not sure what you mean by "power OK",
If you have checked that the logic circuits are getting a clean 5 volts DC THEN the power is OK. This requires an oscilloscope AND a voltmeter.
USUALLY when a display shows characters like that it means the processor hasn't initialized the display. Most common problem is too low power supply that doesn't permit the processor to come out of reset.
Bad filter caps can cause the 5 volts to dip below 4.6 volts which would be minimum to operate. A voltmeter might still register near 5 volts but a scope will show the voltage dips.
Jan 12, 2010 | Alesis Sr 16 Stereo Drum Machine
No display in my intel d945gcnl but power is on
check first your RAM memory and your video card. if ok all. try another ATX power supply.
May 29, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Dell E173FP 17" LCD Monitor Logo
411 people viewed this question
Alun Cox
