Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
Yellow power light on HP SR1420NX
I can turn the computer on and hear the fan running, but the power light is yellow (always been green before today) and the monitor immediately goes into power save mode and shuts down.Can't get the computer to boot up. Was working fine as of last night, this started this morning.
  • Anonymous May 23, 2009
    I tried disconnecting and reconnecting the monitor to the tower. No luck. I can only hear the fan sound though when I try to turn the computer on. I'm starting to get more and more nervous that this is something bad - am I justified?
    P.S. Thanks for answering so quickly
    Novelist:
  • 118 Answers
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
Posted on May 23, 2009
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Tip
Fuse list ford contour
Engine bay fuse box
3 60 Yellow ABS
22 7.5 Brown ABS
32 7.5 Brown Radio
38 Unused
Engine bay fuse box
R3 Blue AC cut-out
R4 Brown AC clutch
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R16 Black Ignition
R17 Unused
R20 Unused
R21 Unused
R26 Unused
Glove box
Step/Courtesy light
Trunk/Cargo area
Instrument-general
on Apr 15, 2015 | Ford Contour Cars & Trucks
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop: Computer powers on, fans work and green light stea...
my gawd, how old is that, over 10y i bet.
yours listed on HP.com not supported.
a dead HDD means (its bad) or you lost 12vdc to it
that means your PSU is dead. 5vdc is ok but that is not enough.
as more are this old. common.
learn to use a voltmeter
see that HDD connector
on pin is 5vdc
other is 12vdc, if 12v is 0v, the motor can not SPIN EVER.
easy no?
Mar 07, 2017 | HP Compaq Presario SR1420nx...
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Laptop won't turn on
not sure but have you checked the backup battery inside
Nov 26, 2007 | HP Compaq nc8230 Notebook
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
206 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
