Question about Garmin zumo 550 GPS Receiver
Speaker doesn't work when using Garmin on my motorcycle but it works in my truck. got any ideas?
Speaker works on my truck but won't work on my motorcycle do i need different wires
  • Anonymous Mar 23, 2014
    We use it in Dallas, Tx. and it will not work. My son tried it in his truck in Dallas and it worked great. What is the problem?
    Welcome Back:
    Visited the website for 2 consecutive days.
There is a speaker on the cradle for the car and none on the bike cradle probably due to the exposure to the elements when on the bike and i think the Zumo must be powered from the bike for the speaker on the Zumo to work when riding.
Posted on May 27, 2009
BOSE CENTER SPEAKER WON'T WORK
Try a different center speaker on the unit to see if it will work, One that you no is good, If it doesn,t work then you no there is a problem with the unit,
Dec 06, 2012 | Bose Audio Players & Recorders
Altec lansing ATP4 speakers aren't working
is it possible that you may have plugged the speakers into the microphone or audio input jack on the computer instead of the speaker/headphone/audio output jack?
Apr 28, 2017 | Altec Lansing Audio Players & Recorders
Yz 250 won't start
HiStart by taking apart the carburetor, replacing the gasket and cleaning it. Then change the spark plug and put fresh gas in. The air filter wouldn't be a bad idea either but you can look at it and tell if you need that. If it doesn't start after that, find someone that can help you troubleshoot.
Hope this works
Feb 23, 2012 | Motorcycles
Bought the stereo 6 months ago, now the speakers won't work!!!! Please help!
Hi, when a speaker does not work, you might need to do some troubleshooting tips to know exactly where the problem is .
First you will need to test the speaker cone if it's working properly by using an AA battery and two wires to make sure the cone is working..
Connect one of the wires to the Positive side of the speaker, and the other on the Negative side, And after that use the battery to hear if the speaker cone will make a click sound.
If it doesn't make a click, that means the speaker cone is Bad, you will need to replace the speaker cone,
But if there is click from the speaker cone, that means the speaker is Ok, and you might need to trouble shoot your stereo to be sure if the sound IC chip is Ok in the stereo..
Hope it helped..
Aug 10, 2011 | Audio Players & Recorders
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
The sound on my garmin zumo 550 is not working right it has been working fine. But this morning when I hooked it to my Harley ultra classic it was reel low upon further check it was only coming through...
sounds like the Audio patch cord, i had around 5 of them that do that ...sometimes i hear the music thru one speaker, cracking noise sometimes it works when the wire is twisted, but i would try a new patch cord first.....my patch cord worked fine on some stereo units others break up
Nov 07, 2010 | Garmin zumo 550 GPS Receiver
My back speaker doesn´t work,, everything is
It sounds like it's your radio if it's the OEM. To make it somple the factory radio had there separate amp muilt in each chanel so if one speaker went bad the others woudl still play. There is no quick fix other then haveing it replaced or if have it repaired.Good luck and just dubble check all the connections
Apr 08, 2009 | 2004 Dodge Durango
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
No voice of speakers
hi the only way the speakers won,t work is if the system has a seperate controled switch on the dash some where and its set in the off position have no idea if yours has one but if a seperate speaker works then so should the cars providing the speakers are there and connected best of luck yates210456
Sep 04, 2008 | 1994 Jeep Grand Cherokee
Garmin zumo 550 GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
