Question about Kenmore Refrigerators
Can't locate the water filter. water has a bad taste
I can't locate the water filter on my kenmore coldspot refridgerator (106.58214400)
  • Anonymous Mar 24, 2014
    Where is water filter located on Kenmore Coldspot model 106.54563300?
  • 6,784 Answers
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
Posted on May 23, 2009
My Kenmore coldspot side by side makes all of my food have a nasty odor and taste, can u tell me why? I tried cleaning it over and over.
Is something going bad in unit because temps are not low enough? Until problem located put an open box of baking soda inside unit to absorb odors.
Jul 24, 2015 | Kenmore Refrigerators
Where is water filter located on kenmore coldspot model #52212100
contact sears parts to get a owner manual but filters are usually locate in line before the unit.
www.searspartsdirect.com
Sep 14, 2014 | Kenmore Refrigerators
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
803 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
