Question about Mtd Garden
Rearend sliping what to do if motor runs fine but when you put it in gear it is like it does not want to go (moves slow not much pulling power) is there a adjust ment or is it just wore out
  • 376 Answers
Have you checked your drive belt(s) for wear or pieces missing. With engine off and clutch/brake pedal up, check the tightness of the belt. You may just need a new belt.
Posted on May 23, 2009
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
1994 yamaha timberwolf will not move when i put it in gear i was riding it up a hill started hearing a bunch of clinging noises and now when i i go to put it in first it wont go any where
You have messed the gears up in your rearend! I have seen on several occasions that the gears on the rear axle were striped! On your rear gear housing there is a screw at the bottom! Remove that screw and gear oil should run out! Let it drain completely! Put ur finger u Der the stream as it is draining and inspect for metal shavings! If there is metal shaving present u have something going on inside there! If the shavings are fine in nature more than likely you have stripped ur axle not that expensive if u diy! But if u can tell there are pretty good size shards in it then u busted gears! Expensive!!
Nov 21, 2014 | Yamaha Motorcycles
42' mower locks up in gear
there are a several gears in the axle that causes the axle to go slow or fast & as well backwards take out rearend & tear it apart & look at gears or have someone look at it for ya
Nov 08, 2009 | Craftsman Garden
**** in power train or rearend
Most likely getting a little wear on the rear pinion, and you are experiencing the backlash from the gears. Put the vehicle in neutral (off) with the parking brake on and twist your drive shaft back and forth. There should be minimal play. If there is a bunch, you have a rearend rebuild in your near future.
Sep 02, 2009 | 2002 Chevrolet Silverado 2500HD
Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Has 6 gears is very hard to shift even R. just happend.
i would check the shift handle see if it is catching on anything if not it could be in the rearend
Jun 08, 2009 | Garden
Automatic transmission kills engine when put into gear.
Do you know what year the 400 turbo is. It sounds like the converter is locked up. I can't remember if any of the 400's had a lock up converter but I will check.
May 02, 2009 | 1994 Honda Civic
1983 dodge power wagon 4x4
put truck in reverse hit brakes constantly and then go for drive in first gear. .... problem was brakes got all locked up ...... to not drive a vehicle is the worst thing u can do to it . hope i helped ELI
Nov 02, 2008 | 1983 Dodge Ram 50 4WD
Garden Logo
126 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
