Question about Amana 3.2 cu. ft. Top-Load Washer
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
MY AMANA TOP LOAD WASHER / MODEL NO: ALW780QAW WORKS FINE, HOWEVER, AS THE TIMER MOVES FROM WASH TO SPIN CYCLE, THE TIMER TICKS AUDIBLY, WHEN NEXT ASPECT OF CYCLE STARTS IE: SPIN OR RINSE, TICKING STOPS. ONLY SEEMS TO HAPPEN BETWEEN CYCLES WHILE MOVING TOWARDS NEXT CYCLE. PLS ADVISE/THANK YOU IN ADVANCE
  • ras55 May 23, 2009
    Thank you, is this something I can do myself?
    Ok, thank you, that answers that question....will be making a repair call....appreciate your time! :)
  • 6,784 Answers
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
Posted on May 23, 2009
  • Michael Masters
    Michael Masters May 23, 2009
    I recommend professional attention in this case. this will require knowledge of minor circuit/module layout and, you will have to disassemble the control panel in order to extract the existing timer control.
  • Michael Masters
    no problem, glad to help:)
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Noisey during wash cycle
sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
Sep 26, 2008 | Amana 3.2 cu. ft. Top-Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
344 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
