Question about HP PSC 2175 All-In-One InkJet Printer
Does not print when I send a job from my computer, the printer responds by sending a blank page. Also print test pages.
Null
  • Anonymous Feb 27, 2009
    the printer does not print when I send a job from my computer, the printer,it responds by sending a blank page thru. the job does not hold in the print queue.the test pages print fine and the HP Printing Diagnostic Utility says every thing is hooked up and installed right,all green checks on list.i have installed this same printer manytimes before as i rebuild my pc every year and a half.this time i got a new copy of windows xp pro with service pack 2 on the disk and updated to service pack 3.it worked fine on service pack 3 on the last build with my older copy of win.xp pro from 2001 tried everything i could think of and still i get blank sheets from the printer when trying to print a picture or text the unit copies fine from it's self but not from computer
My m4345 mfp sends a blank page after print job. How to fix this?
Does it do this on all jobs? If yes, look for a function either in the general setup of the device or the driver for job separation. Having this function on causes the printer to print a blank page between print jobs to help separate them. This not to be confused with the job separation function of the 3 bin sorter where print, fax and copy jobs come out in different bins.
Jan 26, 2015 | Office Equipment & Supplies
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
When I send a job to my printer, it prints out a blank page. Why?I have a Canon MP460 printer
Print a test page using the menu controls. If that comes out blank the chances are either the cartridges are empty or the nozzless are clogged. If so clean them with the pink fluid you get with refill kits, or use the cleaning setting of your printer.
Dec 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Hp 4255, if i send five pages, it shut first five blank pages
check your settings in Start->Settings->Printers->HP4255 rightclick ->properties-> preferences.....
Oct 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Oct 20, 2009 | HP LaserJet P3005n Printer
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printer only works after test page is printed
possible causes:
1. printer driver conflict to other program. Try reinstallation.
2. virus or spyware. check and clean
3. remove all other printers in the list.
Sep 24, 2008 | HP DeskJet 670c InkJet Printer
HP1200 prints blank page
Try ressetting the printer:
Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer
Jun 28, 2008 | HP LaserJet 1200 Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP PSC 2175 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
