Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Ice cube maker just stopped working. Ice cube arm has no tension to it.
Ice cube maker was filled with ice and the bar was up. I shifted the ice out to fill the bin evenly and then after the ice got low again I put the bar down again to start making ice again and it had stopped working. No noise of water filling up and it just stopped. The bar feels like it's loose. Before when I put the bar up there was a tension to it, not anymore. Thanks, Judi
  • jryan100 May 24, 2009
    The model # is 106.9730680 for the Kenmore refrigerator and the Serial # is EC3818645. Hope this helps.
    Thanks
    Judi
  • Kenmore Master
  • 4,654 Answers
If you can find someone that will take yours apart and rebuild the components inside the front of the ice maker would be good. The problem is with older ice makers you may over look the next part to fail. Your model has a tricky spring that helps the arm lock into place. You can visit our site or call the toll free number and get free help and advice. If you can locate your refrigerator model number that will also be helpful Their numbers always look like this for example 213.54698
Click link below and give us a visit, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 23, 2009
  • John Tripp
    John Tripp May 24, 2009
    You are welcome to visit Sears Parts and place your model number of your refrigerator there. Then you get a choice of parts of refrigerator, choose ice maker.This gives you a breakdown of parts and a complete replacable ice maker kit. You can unplug refrigerator and remove ice maker to examine behind front cover. Sometimes you can repaire easly and sometimes it is just better to replace. The ice maker new is possibly a better deal. You can go to my site (cost less) and place the part number 2155184 in parts search or go to Sears Parts Direct you will have to log in there. You can get a user manual for the refrigerator there
    http://www.searspartsdirect.com/partsdir...
    Sears shows breakdown parts for your model but the replacement parts are just too expensive. Look inside your ice maker and see how serious the problem really is first. If you still have problems or questions let me know, Sea Breeze.
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Tip
Ice maker stopped working
When the ice bin fills up, it won't let the arm all the way down. The arm must go down for more ice to drop into bin. Sometimes an ice cube or two will get caught under the arm and prevent it from cycling. Continuing to use the ice maker will empty bin but no new ice is made. Clear any ice cubes from under the arm and the cycle will start again. My ice maker takes about twelve hours to fill after it has been emptied but ice from the door is available almost imediately.
on Aug 23, 2010 | Refrigerators
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
Whirlpool side by side icemaker won't stop... lol
no you shouldnt have to replace the ice maker, the stop arm probably is not in place. pull the ice maker out and check where the arm goes into the motor head. I think that will solve it for you. Good Luck.
Sep 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
232 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
