Question about GE WBSR3140DW Top Load Washer
The cold water won't shut off
The cold water keeps running and won't shut off. The hot shuts off.
    President:
  • 1,136 Answers
Hi, You have a mixer inlet valve going bad. I tried the model # and it doen't show up. Can you check the # one more time please and I will get you part # and how to replace the valve.
Thanks
Vic
Posted on May 23, 2009
94 Buick Roadmaster AC fan blowing hot and won't shut off
If you have climate control it could be the main processor. Something could be shorting the blower relay to keep it on. You would also need to check and see if the system is still full of freon.
Jul 06, 2013 | Cars & Trucks
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Whirlpool front loader -new washer - put in gentle load and keeps shutting off part way with LF -kept trying to start over, even unplug but keeps doing it -have about 5 small items - cold water only -have...
As it's new it will still be under guarantee/warantee? I strongly advise you contact their service desk as you could invalidate the guarantee by following other's guidance. I'm interested in why you have shut off the hot water? Once the temperature is selected by the user, the washer automatically uses a mix of hot and cold water, or just selects cold for rinses etc..
Has the 'LF' been coming on BEFORE or after you shut off the hot water?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool Washing Machines
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water keeps running in i have got to cut water off to spin dry
There is an electrically controlled water valve for both hot and cold water on the back of the washer, do both settings not shut off? if it is just the cold pull the washer out and replace the cold water solenoid water valve.
Mar 10, 2011 | GE WSXH208A Front Load Washer
The water in the bathtub won't shut off. Its a one lever on off. I turned the cold water off but the hot water still leaks out of the fill tube a little bit. Why won't the valve shut off the water
washer and or cartridges have failed and need to be replace to stop your leaking faucet. If it becomes to bad before you can repair them, you may wish to shut off the hot water valve to keep it from wasting hot water.
Dec 28, 2010 | Home
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
Mar 31, 2017 | Bosch Water Heaters
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
