Question about Whirlpool LSR5132PQ Top Load Washer
The machine is not turning on but the power lead is fine.
The previous cycle was completed - now when I pull out the conrol knob nothing happens
  • 6,784 Answers
This is timer control failuer. you will need to replace the timer on this unit in order to restore proper function.
Posted on May 23, 2009
Won't turn on.
solenoid water valve intake gets no power from the program clock the most common problem what will happens if you have an most Italian machine from a FIAT license brand indesit , zanussi , or other italian machine , older so than 4 until 6 a 7 years the brackets on the tank suspension can one of them be broken or a balance spring shock absorber is damaged because of a to heave or unbalanced heavy load and there is a short cable from the power to the program clock with a safety connection if the motion of the tub drum is to great an excessive motion then it will disconnect the cable of some print that leads to the program clock simply made by sliding contacts you can have power off set your program clock just somewhere in the middle of a wash cycle IT can be but not allways it runs when starting the machine it will only turns faster then normal to stop , its a simple but good protection to have more damage if the machine runs with broken parts insite .
Jan 02, 2016 | Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Where is the reset button on maytag atlantis washing machine ,,It is plugged in and turned on at power point ,,Machine is also set and turned on by pulling cycle knob and nothing happens ,,,ie no power
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
Sep 20, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer cycle completes but clothes don't clean!
HEATING ELEMENT NOT HEATING, IF IT DOSE NOT HEAT IT CAN,T MOVE ON
Oct 19, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Cycle completes but doesn't clean!
heater element may not be working,not heating water,good luck
Oct 18, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Whirlpool LSR5132PQ Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
