My 4 yr old refrigerator stopped cooling today. All the lights come on when the doors are opened. Between the up and down temp controls no numbers show, only a green (-) sign for both the refer and freezer.
What's up with that?
Because your digital controls appear to be confused I think the electronic module behind the temp control is defective. The part number for your control board is 12868513
You can enter the model number JFC2087HRP in model and parts search feature at the link below. You may want to unplug refrigerator and examine the part for burn marks or other signs of damage. Let me know what you find, Thanks Sea Breeze
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator...
(More)
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator side on the side next to the freezer. I've checked door seals and they seem to be fine. Temperature settings are set per the manual.
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker....
(More)
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker. Installed it a week ago, and everything seemed fine. Today, it has started discharging water out the water dispenser when the ice maker is going through it's fill cycle. I get some water in the ice tray, and also water spraying out the water dispenser onto the floor. HELP!
Very similar situation where the water dispenser located on inside left side of frig, drips somewhat slowly (around one-two drops every five seconds), but essentially pours out when the ice-maker fills with water.
