Question about Coleman Grilling
Coleman grill gets too hot on low..propane
Even on low it gets too hot..grill is new but bought at estate auction so i dont think a warranty will apply..this is a two burner grill
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
  • 197 Answers
SOURCE: low gas flow into burners despite full propane
The regulator has a hole in it. For gods sake be careful when you are playing around with it, because LPG is heavier than air, we had a leak in our cellar and the fire brigade actually carried it out in buckets! NO joke.They just sprayed a mist of dye over the gas and you could actually see it going down. The gas provider may have come and empty your gas bunker if you have one, or open it and let it dissipate in the open air. Even if you only have a cill on the step of 3", sweep it out like its water. Then change the regulator. Be careful, use pleanty of ptfe tape on the ouutlet side of the regulator to eliminate the risk of further leaks.
Posted on Aug 02, 2009
SOURCE: Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Posted on Oct 25, 2009
Coleman 9921 low flame stove
Tony B. s answer gave me the idea to try and spray carburetor cleaner to try and unclog the filter. Worked like a charm. I now have a full flame coming out of both burners.
Apr 10, 2014 | Coleman Propane Grill Stove 9921-700
New Capt Cook 4 burner - even on Low it goes through 500 degrees in minutes, and there is hardly any difference in flame size between Hi and Low. what's wrong with it - why can't it stay at a low...
I suspect you have a propane grill or it at least the burner orifices are for propane. Because on Natural gas, what you described is virtually impossible. Is it safe to continue to use the grill? Certainly not. Get back in touch with BBQ's Galore dealer you purchased it from (as it's still under Warranty) and have them to either service it or replace it.
Hope this helped you & thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
I have a Coleman two burner propane campstove and
Try cleaning the carbon out of the burners.
Jun 22, 2010 | Coleman Gas Grill Stove
Coleman propane stove, tank got very cold. why?
as propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
May 28, 2010 | Coleman Propane Grill Stove 9921-700
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
Grilling Logo
409 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
