Question about Car Audio & Video
How do i get my ipod to play through the aux line in? i try changing source but only has tuner / cd / standby Thanks
Hi their u might have to go into options on ur head deck try holding down a button to display options and hopefully theirs aux input!!!! and make sure ur pluggin into the ipod is in ur earfones hope that sorta helps u cheers.
Posted on May 24, 2009
Aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Aug 05, 2009 | Kenwood KDC-MP235 CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Playing an Ipod
ya press src until it gets to standby then hold the menu button until it says menu. then press the toggle button down until you see aux and press the toggle to the right to turn it on and be sure to press menu again to set it.
Jan 23, 2008 | Kenwood KDC-MP2035 CD Player
I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Dec 20, 2007 | Kenwood KDC-MP235 CD Player
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Using the auxillary setting
You'll need to turn the auxiliary function on in the setup menu. Press Source to put the unit in Standby, then press and hold the Menu button for at least 1 second. Press the control switch toward AM or FM until the AUX setting comes up, then press the control switch toward <<< or >>> to change the setting to ON. You can download a user's manual here: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Jun 23, 2007 | Kenwood KDC-MP205 CD Player
Car Audio & Video Logo
215 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
