Question about Philips DVD963SA DVD Player
Change area code of device please
How do I change the area code on this device? I want to be able to play both European and us bought discs with it.
    Problem Solver:
  • 15 Answers
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
Posted on May 23, 2009
I am trying to play dvds from England (Region 2) on this dvd player and bought it specifically because it is region free - plays NTSC and PAL, so thought it would be an obvious choice. I can get the dvd to...
Are you in the US? Your TV system is NTSC. The player possibly plays NTSC and PAL(European system) discs on PAL TVs only. Try to find out from the user manual of the DVD player if you can change the output signal to NTSC. Now it is PAL even though you are playing NTSC discs.
Oct 14, 2013 | Pioneer DV-3032KV 1080P Upscaling Region...
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
I bought a Samsung BD C6900 from USA designed for region 1 and A . Living in Europe I cannot play my european DVDs and BDs ? Are there any solutions to change the region code ?
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even after region code hack, it may remain NTSC only, so if you are planning to play European DVDs recorded with PAL system, it may not work.
Feb 27, 2011 | Samsung BD-C6900 Blu-ray 3D Player
My memorex dvd player is reading wrong disc. All of my dvds are authentic so i have no idea what the problem is.
Check ur DVD discs lables said NTSC signal format this format can play only on DVD players was bought in the US,Canada or Mexico.The PAL signal format Discs this format can only play with DVD players that bought in European,Asia,Middle East or African countries.
Feb 02, 2011 | Norcent Technologies DP313 DVD Player
I bought it in Australia, when i got back home (UK) i went to windows explorer and deleted the Australia map and replaced it with Great Britain map from a disc i had. When i turned on the device it says...
It is possible (almost certain) that the GB map you have is licensed to be used on that particular model. It is like Apple not allowing an Ipod owner to play music not downloaded through iTunes. You should consider buying a new GB, or even a European map valid for your GPS.
Jan 03, 2010 | Tomtom One IQ Routes GPS Receiver
I can not play any european DVD on my dvp fx930 bought in USA.Please help i live in Belgium.
you have to change the DVD region setting of the machine to be able to play those european discs. Look for a code to make it region-free if you can. Just do search in the net you might be lucky.
Aug 30, 2009 | Sony DVP-FX810 Portable DVD Player
I have just bought a Panasonic DVD-LA95 but did not realise that it is Region 1 only. I need to change it to region 2 to be able to use it here. Can you help please.
you need to check that it supports pal output, if its a european unit (check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
Jun 25, 2009 | Panasonic DVD-LA95 Portable DVD Player
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
LG RH2T160 unlock all regions
press HOME
scroll to SETUP OPTIONS
scroll - down - to the LOCK icon
press SEVEN ZERO's - message appears
press ENTER.
also used after message; 'unknown disc; please check disc again'..
my indonesia built area 4 marked lg rh2t160 would
play most area 1 dvds, but not all, from new..
7 X 0 hack using remote = plays all discs..
Dec 09, 2007 | Televison & Video
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Philips DVD963SA DVD Player Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
