Question about Frigidaire Gallery Supreme GSTR1670DS 3.1 cu.ft. Front Load Washer
Wont final spin , had loud knock but quit
Fridgidaire gallery started knocking real loud on final spin and now it wont go to final spin
    Sergeant:
    Novelist:
  • 176 Answers
You have a broken shock absorber and you need to relpace it. Remove the lower inspection panel by unscrewing the 2 screw at the bottom of the panel below the door. Remove the panel and look inside on either side of the wash tub. You will see the 2 shock absorbers and one or both will be broken. There are 2 plastic pins holding them in place. On the pointed end of the plastic pin, there is a tab that needs to be depressed (use a flat screwdriver) so that when you pull on the other side with a plier, the pin will come out. Go buy the replacement shock absorbers at your local appliance shop. To install, put the absorber in place and push in the plastic pins. Make sure the correct end is up. Replace the front panel and the job is done.
Posted on May 24, 2009
Washing machine knocking on spin cycle
Unbalanced washing causes that. If it worries you, open the door and redistribute the wet washing.
Oct 21, 2017 | Washing Machines
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
95 4.6 LTR. V-8 was driven through deep standing
Loud knocking is usually a "bad sign". If water got into the engine, and you tried to start it, you could have bent or broken rods. That's a major engine repair.
Oct 13, 2014 | Cars & Trucks
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
I have a 1999 mercury villager and when i press the gas pedal it starts knocking real loud
That maybe a spark knock try filling your fuel tank with 92 octane gas and see if the knock quits.
Oct 17, 2012 | Mercury Villager Cars & Trucks
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
311 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
