Question about Sony KP-51WS500 51" Rear Projection Television
SCREEM TURN BLUE
WHEN T TURN ON TV IT SHOWS OK FOR AWHILE THEN THE SCREEM TURNS BLUE FOF AWHILE THEN IT TURNS OFF BY ITSELF
  • Anonymous Mar 25, 2014
    i have this blue frame that pot up on my tv screem that i can get out
  • 46 Answers
The lamps inside of it are weakening, much like a fluorescent light burns out slowly...so get it into a reapir shop OR better yet, Call for an ESTIMATE or replace the whole thing.
Posted on May 23, 2009
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
My sanyo tv odel ce37ld33-B turns itself off and blue light flashes when i turn it back on
you have bulged capacitors on the power supply board that need to be replace in order to fix the problem
Nov 03, 2012 | Sanyo Televison & Video
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Phillips model 19pfls422d/27 power light turns blue screem seems to turn blue no image on screem
your mainboard has failed and will need to be replaced you can try Andrews Electronics or Partsearch.com
Dec 10, 2009 | Televison & Video
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
My Sony KP-53S35 turns on, shows a blue screen, turns off
It sounds like the blue CRT (picture tube) is failing. The part number for this is 8-733-575-25 but you will need a technician to replace it for you as there is mechanical and electrical alignment to with with it. At that point it probably isn't cost effective to repair the TV. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Sony KP-53S35 53" Rear Projection...
My rca 60 inches big screem will not turn on it
one of the 3 crts are defective.most of the time it is the blue crt.remove the front speaker grille.first disconnect the blue crt board from the blue crt.
try turning on the tv .it will come on if defective.also visually examine the
blue crt board for hair line small cracks.repeat this procedure with the
other crts until you find which crt and or board is defective.
Jul 29, 2009 | RCA Televison & Video
TV SCREAM TURNS BLUE THEN TURN OFF
This is most likely your Blue Picture Tube is shorted, finding a new one, you won't, they are No Longer Available. I haven't heard of any companies still alive that rebuild CRT's. In any event, maybe call a service company to verify your problem. Have a nice Holiday Weekend.
May 23, 2009 | Sony KP-51WS500 51" Rear Projection...
WHY DOES MY TV TURN OFF BY ITSELF AND WON'T TURN ON FOR AWHILE?
There is 2 reasons for this poor solder on power AC board and a capacitor going bad. cap when failing will puff up on top.
Nov 29, 2008 | Akai PT4799HD Rear Projection Television
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
Sony KP-51WS500 51" Rear Projection Television Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
