Question about Hotpoint Aquarius WF000 Front Load Washer
Demo Mode My washer has the on/off button imediately next to the start button: if both are accidentally pressed simultaneously the machine goes into demo mode and displays E5 and will not work. How do I turn demo mode off? There is a procedure where one presses several buttons in sequence or together to unlock - as explained by my engineer but I forgot what he told me two years ago - perhaps someone can help
  • Andyblocker Jan 03, 2008
    Delighted with your help.
    Very many thanks.
    Andrew Straughan.
    President:
  • 1,294 Answers
Try pressing the "on" and "start" button together for over 5 seconds..............
Posted on Jan 03, 2008
Gfd28gelds how do i get this ge fridge out of demo mode because i think it is.
Activate: Press and hold REFRIGERATOR button, FREEZER button and CRUSHED ICE buttons
simultaneously for 3 seconds.
Deactivate: Press and hold REFRIGERATOR button, FREEZER button and CRUSHED ICE
buttons simultaneously for 3 seconds.
NOTE: In order to take the refrigerator out of demo mode, demo mode must be deactivated.
Unplugging the refrigerator will not deactivate demo mode.
Jul 17, 2018 | GE Refrigerators
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
How i get off demo mode
Hello Mark, thank you for your inquiry!
I understand that your Electrolux washer is in demo mode and you need help in getting it out of it. In order to get your washer out of demo mode you would need to turn the cycle selector knob to spin only/time dry. Press start then the cancel button. Activate the control panel by turning the cycle selector knob to spin only/time dry cycle. Press and hold the cancel button with the soil level/extended tumble button (third button from the left) for three seconds. This should deactivate demo mode on your washer. If you continue to experience issues with your washer please comment back and reply with your model number. You can locate the serial tag (which lists your model number) on the door frame of your washer. I hope this information is helpful to you. -Matt
Dec 16, 2015 | Electrolux Washing Machines
Disable demo mode on nook hd+
Go to settings, then device information. While pressing the volume up button, tap above the volume bar and a popup menu will appear. Uncheck "Enable demo mode", then power down your Nook. When you restart it, the Nook should be in regular mode.
Nov 01, 2014 | Nook HD+
The letters DENO is chown on the display
Hello & Welcome to FixYa
The washer is in DEMO Mode and to deactivate it there are three ways depending on the age of unit:
1. Press Start/Cancel button untill all console LEDs illuminate....Then press both Start/Cancel and On/Off buttons together until d OFF appears on display.
2. Press the CANCEL button to cancel the DEMO mode.
3. Press the On/Off and Start/Cancel button together with the top left button option until the d Off appears
Please get back to me if you have any other questions.
Kevin
Jan 26, 2011 | Indesit WA 125 Front Load Washer
Keeps coming up test when i turn it on
hold the start/pause & the on/off buttons simultaneously for 5secs and off as when these 2 half buttons are pressed together it initiates shops demo mode..
Dec 14, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Wf860p computer control automatic
I have had this problem it is caused by accidentally pressing both the on and start button together. It puts the machine into demo mode. You need to press both the buttons together again for about 30 seconds. If it doesn't work first time switch the machine off and do it again. Sometimes you have to do this many times before it works but eventually it does work.
Very frustrating.
I found the cause was either leaning on the front of the machine or resting a broom which when you pick it up accidentally presses the two buttons.
Sep 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
428 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
