Question about Microwave Ovens
Stopped heating I was reheating soup and after three minutes the soup wasn't even warm, so put a cup of water in for a minute and still no heat, what do you think is wrong ? This unit was purchased at Wal Mart approx a year and a half ago and is not used for 5-6 months of the year when I am away. I would appreciate any help Thanx R Rogers
  • r_b_rogers May 24, 2009
    This is a
    Danby0.7
    Model #67638 70001
    Ser # 1707061207475
    The clock and timer work also turntable
    but NO HEAT
    rbrogers
  • 180 Answers
You have not mentioned the make and model of the oven. Any way you can check if there is a fuse between the highvoltage terminal of the transformer and the high voltage capacitor. If it is blown off youcan replace it by similar value. Still it is not heating you have to replace the magnetron.
Posted on May 24, 2009
Sounds like its running, but will not heat
Good Morning Friend,
I understand that your Frigidaire microwave, model# MWV150KBA, sounds like it is running but will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes.
Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button once for AM and twice for PM, enter in the time, and press the "Clock" button again.
Put a cup of water in for about a minute. If the water does not get warm, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your microwave and determine why it is not heating. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
4 minutes to make cup of soup luke warm
Weak magnetron, or transformer, not worth repair as the cost of parts alone can buy one to two microwave ovens.
Jan 01, 2010 | Microwave Ovens
Microwave doesn't heat up
There are three solutions (source) =>
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Dec 31, 2008 | Microwave Ovens
Microwave seems to work OK but doesn't heat
The ray tube is dead, cheapest fix is get new microwave.
Dec 29, 2008 | GE Microwave Ovens
What ARE those small black particles/chunks?
You probably avoided a lot of hassle by replacing the oven.
Dec 15, 2008 | Microwave Ovens
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Oct 16, 2008 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
