Question about Samsung Televison & Video
Rear projection tv screen warped
Hi, I was just wondering if it was possible to repair a samsung rear projection tv. The picture is all warped and wavy with green and purple smudges
double vision at the top of the screen, blue and yellow lines.
  • 6,784 Answers
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
Posted on May 23, 2009
Warpped TV picture
There are two problems here but may be caused by one component
The flyback transformer or transistor equivalent is faulty The colors are warped convergence controls which may be due to a faulty sustain board or part of the first problem. DIY is not an option and repair estimate is about $3-400.00
Please rate my help++++Thanks for uyisng FIXYA
May 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
I have a samsung 65in hdtv rear projection and the colors dont line up it looks like triple vision what could it be
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Samsung HCN653W 65" Rear Projection...
We have a Hitachi projection tv maybe 54" that worked fine yesterday but today has shadowing/ghosting in pink & green. Wondering if there's something easy to try to fix? If not, is it worth getting it...
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 03, 2010 | Philips 60PP9352 60" Rear Projection...
I have a samsung rear projection tv and has ghosting on picture? what could be wrong and is it easy to repair?
*Screen Looks 3-D
*Colors wont align
Problem #2
Jun 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
*Screen Looks 3-D
*Colors wont align
Problem #2
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A--- $38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
May 07, 2009 | Samsung HCM4215W 42" Rear Projection...
Mitsubishi VS-45609 Blue layer is distorted and seperated
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Dec 30, 2008 | Toshiba 55H70 55" Rear Projection...
Warping picture and color separation
The convergence chips and resistors need to be replaced. You can get a repair kit and photo instruction guide from www.TvRepairKits.com.
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Rear screen projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
338 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
