Question about HP LaserJet 2840 All-In-One Printer
HP color laser jet 2840 feeder is broken
Soon after replacing cartr. the black new line started showing on all prints from feeder , now can't even feed the document thru
we can only use the glass option -one page at a time
  • 1 more comment
  • boalexander May 23, 2009
    printer was fine before
    but my multiple attempts to get clean and get rid of lines resulted in total feeder malfunction
    paper doesn't go thry any more
  • JDTec
    JDTec May 11, 2010
    You must have disloged the paper sensor in the ADF. Open the ADF cover and look for the paper sensor. It is spring loaded and it may have come loose. Also, with the ADF cover openned, try to manuall feed a piece of paper to see where it gets stuck.
  • JDTec
    JDTec May 11, 2010
    Was the black line showing with the old cardtridge?
    Are you trying to feed throught the ADF (document feeder, but cannot?
    If you cannot feed using the ADF, you may have to clean the rollers. And if the black line shows up when you do feed from the ADF, you have to clean the narrow glass pane on the left of the big glass pane.
  • 52 Answers
Something might be blocking the light from the scanner lamp to fall on the originals. Try cleaning the glass covering the lamp.
Posted on May 23, 2009
  • Kaviraj Ramputty May 23, 2009
    Check the paper sensor and the feeder mechanism
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Hi there , I have a HP 2840 Color Laser Printer that is saying "Replace Supplies " . All cartridges are showing "empty" besides yellow . I only wish to replace the black cartridge and...
There is no option like what you are expecting. But now a days all chips are avil in market simply replace the chip & cut the cost...
Sep 12, 2011 | HP LaserJet 2840 Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Needing a users manual to trouble shoot printing issues
Hp has most of their user manuals online. Go to hp.com and you should find yours on the list. God bless.
Jan 13, 2009 | HP LaserJet 2840 Printer
Hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Dec 15, 2008 | Office Equipment & Supplies
HP Laser Jet 2840 printer
If this is happening when copies are made only and not on prints from the computer, lift the top doc feeder lid and located the strip of glass. You should be able to locate a spot of ink or white-out or something else on the glass strip. The scanner for the doc feeder moves the original paper over this strip window to scan it. A dot will appear as a line. Put some Windex or similar glass cleaner on a rag and clean the glass well. Shoot, while you have it open clean all the glass and all your copies will look better.
If it's happening in copy and printer mode (sent from computer), check the toner caridge for damage to the drum. To check the drum, simply flip open the shutter that has the HP logo and part number on it. You'll see a black tab hanging out past the left handle. Move the tag downward to momentarily view the drum. Keep the drum out of direct sunlight or bright lights as they are light sensative.
If there is a line on the drum, replace the cartridge.
Hope that helps you. If so, hit me with a FIXYA. If not click on my user name and let me know what you find so I can isolate it further for you.
Thanks.
Aug 30, 2008 | HP LaserJet 2840 Printer
Hp 2840 "Replace supplies"
If one of the color cartridges runs out the machine will switch to black only mode. However, I have found no way to force it to continue printing in color mode when any one of the cartridges runs out.
Apr 26, 2008 | HP LaserJet 2840 Printer
REPLACE SUPPLIES
Make sure all cartridge are install and secured into place...(take all the cartridge out and back in ) close front door cover and it will go into cartridge calibration...If not, press the "menu" key and with the arrow go to print quality and confirm with the enter key. Go to calibration and confirm...
Let me know....
Mar 26, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
210 people viewed this question
Seeker5211
Seeker5211
