Question about Alesis Fusion 8HD Sound Card
Alesis Fusion HD8 no left channel output on mains and headphones
No left channel output on mains and headphones. The audio also distorts on when played.
I have reboot holding the play/record buttons. Checked other forums for similar issue.
2 Suggested Answers
SOURCE: No sound
I had that on my HD8. I had the extremely faint sound problem, too. Volume did nothing.
In my case it was the I/O card (part number AL9-79-0313-A), which feeds the headphones and other outputs. At one time the card was about 115 dollars, I think. You can call Alesis parts and try to get one. Be aware, though, that it is possible something else popped this board, as some Fusions had a power regulation issue in the past (I wish I could advise you specifically on that, but I can't find out the details myself.) So far, mine is working wonderfully.
(Actually, on my I/O card it was one blown transistor and a fried quad op amp. The transistor applies or removes voltage to the output op amps as told by the MUTE signal, which I suppose is to keep your speakers and ears from popping when you turn the Fusion on. That made it like MUTE was on all the time, with the smallest amount of leakage if you listen really close in headphones.
I got it going because I have done electronic repair work for years AND because Alesis was kind enough to send me a PDF of their service manual. And God helped me, or at least kept me from ruining it further by giving me some patience. No parts looked bad that actually were bad on the IO card. I felt fortunate to get it working this way, as the surface mount parts are tiny, and it's been awhile since I did much electronics.
If you do take this dude apart, be very careful not to pinch the large gray ribbon cable (looks like a hard drive cable) in the back of the keyboard putting it together again. Don't ask how I know that...
Posted on Nov 18, 2008
Audio Output signals distorted
Without knowing what make and model of whatever you're asking about we can't be specific.
But if all outputs are distorting. Either the preamp is driving the amp too hard, or the amp is fried and needs repair/replacement.
Aug 30, 2016 | The Music
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
Analog Audio Out signal has very high distortion. Signal wanes in and out, wanders from one channel to another, and develops high static. This happens when Audio Out is configured for Fixed Output. When...
The problem is more likely to be with the wireless headphone set rather than the TV. It makes no sense that the signal changes channels. The only difference betweent he fixed and variable output is whether or not the volume changes the output signal amplitude. The channel selection process is not handled there. The distortion is likely due to the input of the wireless being overdriven. If available, turn down the input gain on the wireless and try again. Please update this with the results.
Thanks,
Dan
Feb 28, 2011 | Televison & Video
THE POWER LED HITS RED AND STAYS THERE AND THE ONLY OUTPUT THAT WORKS IS THE HEADPHONE BUT ITS SO LOW YOU CAN HARDLY HEAR IT
Issue with Voltage Regulator... also main board damage due to over heat... Check Regulator input and capacitor fail to innitiate to IC Chip... Unit seriouly damage dont plug anything On it you may damage the rest of your electronic equipment ...
Sep 30, 2010 | Alesis io 2 Portable 2-Channel 24-bit...
No sound
مرحبا لدي مشكلة في تعريف كرت الصوت برجاء مساعدتي في حل هذة المشكلة لانة ليس لدي سيدي لتعريفه وشكرا
Sep 15, 2008 | Alesis Fusion 8HD Sound Card
No sound ...
Go into global settings, choose the MIDI settings and make sure the very first box is checked. I lost my sound and had a similar problem and just did some troubleshooting and once I clicked that box, my sound returned. Hope this helps.
Sep 14, 2008 | Alesis Fusion 8HD Sound Card
Alesis RA500 amp - channels crackle, distort, cut out
you have a problem in output stage and output ic need to check or replace.
Jan 27, 2008 | Audio Players & Recorders
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
Distorted Front Right channel
check some caps in the aduio section alon with transistitors
Apr 04, 2007 | Onkyo TX-SR503 Receiver
Alesis Fusion 8HD Sound Card Logo
156 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
