Question about Whirlpool GEW9878LW Electric Dryer
My dryer does not get hot .
My dryer runs but does not throw any hot air. What do I need to replace to fix the problem and where is the part located in the dryer.
  • 59 Answers
First i would check that the vent is clear. then go to the heating element.
Posted on May 23, 2009
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    2004 camry ac light blinking and throws hot air. Suggestions?
    My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
    Apr 03, 2012 | Cars & Trucks
    Dryer is running and turning but not throwing hot air.
    Check your breakers by forcefully turning ALL THE WAY off. Often 1/2 of the circuit will trip, but not the half running the motor.
    Nov 01, 2010 | Kenmore 400 6943 Dryer
    My roper dryer will run for few minutes and throw a breaker.It gets hot and spins just throws breaker
    check the vent i went on one that done that if vent is clear and no other signs replace breaker
    Jun 08, 2010 | Roper RES7646KQ Electric Dryer
    My dryer turns on but throughs out cold air
    In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on yourspecific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINEUNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week.
    Jan 03, 2010 | Washing Machines
    Electric dryer works but not throwing hot air
    ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
    Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
    Sounds like your problem may be with the heating coil.
    Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
    Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
    You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
    If the heating coil is ok, then:
    You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
    If the coil heats up then replace the thermostat/thermistor.
    DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
    I will include these two websites for parts and further help:
    http://www.partselect.com/
    http://www.appliancepartspros.com/index.aspx
    Both also have chat assistance 24/7.
    Good Luck,
    Hope this helps
    Please rate me,
    Thank you
    Dec 02, 2009 | Whirlpool GEW9878LW Electric Dryer
    Amana dryer
    If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
    Oct 02, 2017 | Dryers
    My dryer is ot blowing hot air
    Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
    Dec 31, 2008 | Kenmore 75962 Gas Dryer
    Dryer does not get hot
    pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
    Jul 20, 2007 | LG DLE0332 Gas Dryer
    Whirlpool GEW9878LW Electric Dryer Logo
    265 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
