Question about Creative Labs I-Trigue 2.1 3300 Computer Speakers
My Creative speakers are not working
My speakers are not working there plug in right but there is no sound?
  • 192 Answers
You may have on of the computers volume controls on mute or way down where no sound can be heard
Posted on May 23, 2009
3 Suggested Answers
  • 71 Answers
SOURCE: Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
Posted on Jun 02, 2009
preachw996
  • 1179 Answers
SOURCE: No sound from rear and center speakers Creative t6100
Go insto your speaker properties/configuration from the little speaker icon in your taskbar. Check to make sure you have it configures in a 5.1 format rather than stereo. If it is set in stereo change to 5.1 & hit the test icon. All speakers should now be working. Hope this helps.
Posted on Jun 08, 2009
I have creative A60 2.0 speakers plugged in to PC but sound only coming out from left speaker
The plug going into the PC is a stereo plug - it has a section for right, left and ground (return). If it's not plugged in all the way or the mating connector is faulty, you will have the symptom you describe.
Phone connector audio
Feb 12, 2015 | Creative A60 2.0 Speakers
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Feb 16, 2012 | Harman Kardon Audio Players & Recorders
This hardware (creative sound blaster ct4650) is not work properly
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps if you dont have the drivers
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html hope one of these will help you
Jun 24, 2011 | Acer Creative Sound Blaster AWE64 Sound...
Front right speaker is not working
This may sound obvious, but have you plugged in all the plugs?a 4-channel sound system has two plugs that plug into the sound card.One is for the front speakers and part of the subwoofer, the other is the rear speakers and the other part of the subwoofer. AC97 audio normally supports only 2-channel.s your sound on-board?how many sockets does it have.A common AC97 normally has a green plug (for 2.1 speakers), a blue one for line in and a red one for a mic.A four-channel one will have a black socket for the other two speakers.and 5.1 has a yellow socket for the 5th speaker and woofer.
If your AC97 audio does not have the black socket, then you will need to buy a special card, like the Sound blaster 4.1 Digital (around £20-30).Or, if you want a 5.1 card, the Creative Audigy is considered the best, as the Audigy 2 is still expensive, and there are cheaper cards for 4.1.
Hopefully this should sort out the problem.I also have Creative Inspire M4500 4.1 speakers, and they have 2 plugs.
Jul 07, 2009 | Creative Labs Inspire 4400 Computer...
I have plugged in my speakers at right place but no sound is coming out of it. I also have a sound card of realtek nothing is helping. Please provide some solution.
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Jun 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Creative Labs I-Trigue 2.1 3300 Computer Speakers Logo
748 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
