Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Thermostat does not shut off A/C at desired temperature
Intermittent problem.  if I set the thermostat at 78 degrees for the A/C,  frequently the thermostat will not shut A/C down at 78, but has continued as low as 73.
  • HANK MCNEIL May 11, 2010
    Don't think it is the T87 thermostat but if it is the only thing you can do is replace it. If it's not that, it's gonna take some detective work by someone who knows how it works.
    President:
  • 3,433 Answers
Sounds like a bad thermostat.
Posted on Jun 01, 2009
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
Cant program remote
I'm going to assume you are meaning that you are unable to set the "target temperature" for the thermostat?
This remote control system can be thermostatically controlled when the transmitter is in the THERMO mode (THERMO must be displayed on the screen). To set the DESIRED room temperature, press the MODE button to place the transmitter into THERMO mode, then press the UP or DOWN button to select the desired
room temperature. The highest SET temperature is 99 degrees Fahrenheit (32 degrees Celsius).
The complete owner's manual can be downloaded from the product page below, just scroll down to the bottom and click the link.
Skytech 3002 Thermostat Fireplace Remote
Sep 23, 2012 | Skytech 3002 Fireplace Remote Control with...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Hunter set and save prorammable thermostat 44155 want shut off at desired temperture. I have the thermostat set at 80 during the daytime when I am not home and 78 for evening and night. The thermostat will...
Possible that the sensor is not reacting and so does not set to the data required in the program. Try and see what is the error factor for the switch on and off which will give an indication of the sensor error. If so this must be replaced. otherwise you can use the error to set it likewise., higher or lower.
Sep 29, 2011 | Dryers
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
Jul 14, 2009 | Carrier 38CKC036 Air Conditioner
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
661 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
