Question about Chicago Pneumatic 864 6" Heavy Duty Dual Action Air Sander
DA SANDER RPMS SLOWED
CHICAGO PNEUMATIC CP870 DA SANDER LOST RPMS .IT WAS WORKING FINE BUT SLOWED WAY DOWN.WHILE HARDLY SAND OFF BONDO IT IS SO SLOW
  • 3 Answers
Get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
Posted on May 24, 2009
My CP7200S has stopped working. The air simply comes out of the bottom of the sander through the filter. Any suggestions?
the units gummed up from the air,get a can of air tool oil and pour it into the air hose inlet,then work the trigger to let the oil into the sander,then pour more in and connect the air hose and see if it will start,if not you may need to dis assemble and one of the reeds may be frozen in place or stuck letting air go by it and out the exhaust
May 19, 2011 | Chicago Pneumatic Cp7200s Mini Random...
DeWalt DW 421 palm sander. Sander was working. All at once it lost power.Did not quit, just slowed down. When I lifted it off the board it sped up,but when I tried to sand again it slowed down-lost power....
From your description it sounds like the bearings on the armature seizing up . Mainly the bearing on the bottom towards the pad. I see it a lot . It'll seem ok when turned on but under a load it can stop , slow down , smoke ....I'd start by checking the bearings. If it was the cord power would cut in and out completely. It doesn't have a variable speed switch or any speed sensors on that model. .if you have any questions feel free to ask and give as much detail as possible plz.
Oct 01, 2017 | Dewalt Tools & Hardware - Others
HOW DOES IT WORK WITH NO CORD???
If the product your have this listed under is correct then you need to hook up an air hose to this sander to make it work...it works on compressed air...
heatman101
Aug 21, 2010 | Chicago Pneumatic Cp7200s Mini Random...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Sander will operate only at a very low level of power.
It is either a bearing or bearings that are failing and causing the sander to slow down or the variable speed switch is failing.
Mar 17, 2009 | Tools & Hardware - Others
Trigger is stuck
I had one do the same thing and all i did was spray some wd40 all around the trigger its lie a plunger valve and alot of dust was built up in mine ...It worked on mine hope it helps yours
Jan 29, 2009 | Chicago Pneumatic Heavy Duty Jitterbug...
Air Sander Question
When you are finishing the surface of wood, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Aug 27, 2008 | Taylor Pneumatic: Orbital Sanders:...
Air sander Support
You can add different sanding discs to an orbital air sander to ensure that it is properly set up for a huge variety of different jobs. From heavy duty sanding paper for tough jobs through to buffing cloths in order to get a final polished finish at the end of the job. With most orbital air sanders, changing the disc takes just a few seconds, allowing you to get a variety of jobs done a lot quicker.
Aug 27, 2008 | Chicago Pneumatic C-P AIR SANDERS & FINISH...
Chicago Pneumatic 864 6" Heavy Duty Dual Action Air Sander Logo
504 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
