Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 with no video. sound ok. B&W squares pattern on pict.
If you know or somebody knows what is the problem, please let me know. I replaced the lamp and the 2 capacitors in power supply already, still same problem
Thank you.
    President:
  • 4,402 Answers
Hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
WD-52525 with black and white little squares. it has sound.
Tile or block pattern with no video or OSD. Suspect the FMT PCB part # 930B924002.
Oct 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mits WD-52525 random 1-pixel jitter
if you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Jun 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black and gray boxs show up on my screen
try to hook up signal diffrent instead of rf go video, or s video
i would try video if you have original remote see what happens
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-52525
first unplug and let it sit for a couple of hours and then try again.
Jan 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
