Question about Nikon COOLPIX S51 Digital Camera
Memory card it write protected
I tried sliding the slider button on the memory card. It did not work. I also tried removing the battery. It did not help either.
    Sergeant:
  • 246 Answers
If you have tried the button on the SD card, and it didn't solve the problem, you may have a problem with the SD card slot. You need to open up the camera and check the switch on the SD card slot.
Here is the tips may help you.
How to fix a ‘card locked’ problem
Posted on May 23, 2009
SD card is protected in my camera need my photos
There is a small white button on a slider on that card. Might it be that it has been protected by it?
Try sliding it towards the opposite of wich it is and make sure it stays!
Then retry!
Feb 10, 2012 | PNY 2GB microSD Memory Card
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
I am trying to erase pictures from the memory card however it says card protected and the key symbol is showing in the top left hand corner how do I take this off
Hi
Thank you for using Fixya!
Remove the memory card, check the sides for a switch or a slider. slide it or switch it on the opposite direction. Reinsert memory card and try deleting the photos again.
Hope this help
Sep 17, 2010 | IT Works 3045 Digital Camera
My mem card will only let me move pictures from my cell TO my computer but not also FROM my computer to my cell like it used to before it says "Remove the write on protection or use another disk" i dont...
This should help fix the issue,
You will have to open MY Computer or COMPUTER from Start button. Make sure the SD Card is connected to PC.
1) In My Computer, right click on the drive letter of your SD card and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, Proceed with your copying.
5) If it DIDN'T work, repeat steps 1 through 4 ( 2-3 times )
If this does not work, there is alternate method.
The Memory card has a write protect slider on the side. Try putting tape around the card to make sure that the slider thing does not slip into write protect mode when inserting the card.
Sep 07, 2010 | SanDisk 2GB microSD Memory Card
Memory gone wright protected
You may have moved the little slider on your memory card that makes the card write protected. Remove the card and slide the little switch on the left hand side.
Aug 30, 2010 | Nikon Coolpix 4100 Digital Camera
My memory card is write protected how to remove its write protection?
Some cards have a little white slide button at the side of card flip it the other way.
Apr 14, 2010 | SanDisk 2GB microSD Memory Card
D-395open lens you get a blue screen says write protect?
Check for a small slider on the memory card - it sounds like the card is set to "protect" mode, which means you can't write to it. Slide the little slider on the card, reinsert and try it again.
Oct 20, 2009 | Olympus Camedia D-395 Digital Camera
Memory card is write protected how can i sove this'' Problem
remove the card from the phone, there should be a small slider switch on the side of the card slide it along and it should work. good luck
Aug 20, 2009 | Motorola Mobility MOTOROKR E6
AIPTEK IS-DV2
First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
Jul 08, 2008 | Aiptek IS-DV2 Camcorder
Can't take photos. Screen reads "Memory card is write protected " How do I undo this ?
On your memory card there's a tiny slider button. Slide it along to the other end and see if that helps.
Apr 27, 2008 | Nikon Coolpix 4500 Digital Camera
Nikon COOLPIX S51 Digital Camera Logo
188 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
