Question about Whirlpool GHW9150 Duet Washer
Clunking (banging) noise when in use.
It is out of warrenty and it is making a clunking noise when in use. What could the problem be? Is there an online guide for disassembling/reassembling on this model?
  • dav4cap May 24, 2009
    You identified it 100%, thank you.
  • Whirlpool Master
  • 3,361 Answers
The rear tub support is deteriorated.
The complete tub must be replaced.
Posted on May 23, 2009
Makes clunking noise just inspect inlet and outlet baffles area loose which is the right position ?
What do you mean by clunking noise, a single hard bang or like popcorn popping around inside? Right position an what part exactly, what is loose, baffles on top of the exchanger? What model heater?
Apr 05, 2014 | Hayward Pool & Spa
Clunking noise
My 2006 Dodge Ram 1500 makes a clunking noise when acceleration from a stop. and also while driving sometimes in low RPM.
Jan 04, 2014 | Remington 660/774 Right Side Crank...
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
The steering on my citoen zara 1.6 is making lots of banging noises when turning It pulled left for a while then after some noises returned to normal
your clunking is probably caused by a bad steering u-joint or knuckle at the bottom of the steering column.(at rack and column)
Aug 31, 2012 | Cars & Trucks
My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
GMC JIMMY making clunking noise in back
I believe I would carefully check the u'joints first. Get under it with the emergency brake on,the wheels chocked and the transmission in neutral.
Check if there is any slack or movement in in the tube..
I hope this helps. Robert
Jan 26, 2012 | 2000 GMC Jimmy
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Apr 06, 2009 | LG LDF6920ST Stainless Steel 24 in....
Washing Machines Logo
272 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
