Question about Whirlpool GEW9250 Electric Dryer
Whirlpool dryer not heating-
Going to have dh check the venting-do i even want to mess with replacing the heating fuse? where would i buy that? should i just get a new one....not sure how long dryers are supposed to last these days. mine is only 5 years old. no problems ever up until now.
    President:
  • 1,136 Answers
HI, To get to the element, you have to remove the lower front panel. You will see the element on the right side under the drum.
With the dryer running, you should have 240V the the two terminals on the element.
If there is voltage, replace the element. If there is no voltage, check the thermastats and the fuse. UNPLUG the dryer and check them for continuity. They should be closed.
This dryer is worth fixing. They are good ones.
I can help you with part #'s or answer more questions if yyou need.
I hope this helps
Vic
Posted on May 23, 2009
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool dryer no heat mod ler8648pg1 help please..
    Hi
    The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
    To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
    Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
    Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
    Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
    http://www.dryernotheating.com/
    http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
    http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
    Please get back to us if you have further query else please accept the suggestion.
    Feb 01, 2011 | Whirlpool Dryers
    My gas dryer has no heat
    long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
    Feb 22, 2010 | Whirlpool LGB6300 Gas Dryer
    Dryer blows limit fuses, have replaced before.
    The vast majority of dryers that blow high limit fuses have the same problem: Lack of airflow. If anywhere in the venting system for your dryer is restricted your dryer will heat up too hot. The excessive lint in the filter, a clogged dryer vent hose, the vent within the house, even within the dryer itself all are places where a restriction could occur. Check all of these for being restricted. Also make sure if you have a flexible hose between the dryer itself and your dryer vent on your home, make sure it is not crushed when the dryer is in place. This will cause your limiting fuse to blow very quickly.
    When you remove the hose from the back of the dryer you can check that the dryer itself has decent airflow by starting the dryer on the fluff/no heat setting. This will give you an idea whether it is restricted inside the dryer or not. If you even have a hint that it is not putting out the air it should, have it cleaned (or if you are mechanically inclined do it yourself just make sure the dryer is unplugged).
    Then have the dryer vent system cleaned. Replace your high limit fuse and you should be back in business.
    Nov 03, 2009 | Whirlpool Dryers
    Dryer won't heat up
    You've got an intermittent open circuit in a gas valve solenoid---for about 10 to 20 bucks you can buy a pair on line and do replace them as a pair if one is going the other will also soon.
    If you keep messing with it it may stop igniting completely---then you can test the 2prong solenoid to be sure this is the problem---should have about 50ohms.
    Jul 14, 2009 | Whirlpool GEW9250 Electric Dryer
    My whirlpool duet front loading dryer does not have heat
    Check the following to address this issue.
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Heating element
    A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
    3. Thermal fuse
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Jul 09, 2009 | Whirlpool Dryers
    Won't heat
    2. Heating element
    3. Thermal fuse
    Jun 20, 2009 | Whirlpool GEW9200L Electric Dryer
    Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
    2. Heating element
    3. Thermal fuse
    Jun 18, 2009 | Whirlpool Dryers
    Dryer running but not heating. How do I check heating element?
    Check the following to address this non heating issue
    2. Heating element
    3. Thermal fuse
    Jun 02, 2009 | Whirlpool Dryers
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool GEW9250 Electric Dryer Logo
    127 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
